Help! Power seat barely moves
I need to remove my seat but it won’t move forward or backwards enough to access the attachment bolts. Any suggestions on how to remove it?
Old 10-23-2019, 08:53 PM
proporsche's Avatar
try to do it with a jumper on battery..also look with a flashlight for obstruction on the rail...
Sweet jesus ...adjust your handbrake;-)
ivan
1985 911 with original 502 191 miles...808 198 km
Old 10-24-2019, 09:37 AM
Sometimes one flex cable comes out of the motor and the seat only moves a bit on the still driven side.
206 637 4071
Old 10-24-2019, 09:51 AM
proporsche's Avatar
also..try to lift front and rear.... 1`st,then see inside the rails...
Old 10-24-2019, 12:06 PM
El Duderino
tirwin's Avatar
In addition to the above, you can try spraying some contact cleaner on the controls. My friend got his driver seat stuck forward in his 968 and I sprayed it with Deoxit D5 and it fixed it. Sometimes it’s better to be lucky than good!
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 10-24-2019, 02:33 PM
spielzeug's Avatar
Isn't there a manual drive accessible from the front of the seat?
Old 10-24-2019, 06:18 PM
famoroso's Avatar
ivan
Amen brother Ivan! Three clicks only please.
DeOxit FTW! Many times it's all that's needed to fix this issue.
Yes, there is. Consult your owners manual.
Frank Amoroso
911 M491 / M470 coupes:
1987 GP Wht / Blk "Apollo"
1987 Gemini Blue / Blk "Gemini"
1989 GP Wht / Blk "Vents"
Old 10-25-2019, 07:15 AM
Thank you everyone for the feedback.
Handbrake: it’s on the list but lower in priority than the seat. I’ll over 6 ft so a higher priority is the seat. I got this car last year and slowly working it back to health. I think I have all mechanical dialed in. I love working on these cars.
The seat switch is fine. The front servo motor works. It looks like there are two screwdrives, one on each side of the seat driven by the one motor at the front. the outside screw drive functions properly however the inside does not move. I looked at the Bentley manual and there’s nothing about how to remove a power seat when not operating. If anyone has an excerpt from the owners manual about how to do that, I would appreciate some advice.
Old 10-25-2019, 06:26 PM
Crap. I found the front screw but the plastic gear broke.
Old 10-25-2019, 07:49 PM
Pull the cable out of the motor and turn it with anything that fits the square end, like mini visegrips, or a mini crescent wrench, etc. then walk the seat back by alternating the motor on one side and manually turning the cable on the other.
206 637 4071
Old 10-25-2019, 09:31 PM
