rick conrath's Avatar
cd box failure?
Went for a fun run today...and my car died halfway out. What I noticed was that the cd box was not humming with the key in the on position. After about an hour...the box started to humm again and the car started right up. Let the car idle for 15 minutes and the car would die again after warming up (no humming from cd box) Is this a bad cd box or a bad relay that is responding to the heat?
If the cd box is bad...I am thinking of an MSD unit.Opinions?
thanks,
Rick '78 930
Old 03-29-2003, 02:03 PM
there is a cd box thead on early s. you might pick a spare up. the word rebuildable comes up, but in my hands that my mean something else.
check your power supply and search supermans threads. ( ie relay under passenger seat )
72 911t grey/black mine
74 914 2.0 black/ tan hers
02 g500 black/black womanproof
01 f250 psd dirty the mule
60 correct craft starflite cool
69 correct craft torino hauls butt
72 correct craft ski nautique fun
66 vw 1500s will finish someday
Old 03-29-2003, 02:36 PM
I have a 1970 S. I had the same thing happen to me.
Check the ground. The braided wire attaching to the clip on the CD Box to the body. Check all GROUNDING points.
If you have to rebuild, call our host for the exchange.
Old 03-29-2003, 03:10 PM
I thought ground at first....but it dies after heating up, or running for awhile. I will check connections.
Old 03-29-2003, 03:37 PM
Cool
when it's dead check positive at the box
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-29-2003, 03:40 PM
pwd72s's Avatar
Hmmm. Does this mean our host sells rebuilt 3 pin units? I could buy one outright? Please don't say search the catalog...I have a hard time negotiating on line catalogs.
Old 03-29-2003, 06:15 PM
Early_S_Man's Avatar
Porsche Crest
Yes, Paul, thet do ... but, STRANGELY, they aren't in the '65 - '73 catalog!!!
CD Unit, Rebuilt, 911 (1974-77) [Photo]
A-602-702-00R $225.00
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 03-29-2003, 06:24 PM
You are referring to positive going into the box I assume. I will have to move a bunch of stuff to see where that is. Intercooler, etc. It makes sense to me that this intermittent behaviour, is due to the effect of years of heat from my turbo on the box. I can only assume that this is the original box('78 vintage), so it's probably seen better days. If there is no power going to the box when it dies, then it's a hunt for a short going back to the fuse panel?
Old 03-29-2003, 06:45 PM
What about the MSD units.....?
Old 03-29-2003, 06:46 PM
Cool
"You are referring to positive going into the box I assume."
--- Yes.. I'd probably rig some kind of a test wire to the positive so I could check it quickly.. then attack other stuff while the unit is kaput
" It makes sense to me that this intermittent behaviour, is due to the effect of years of heat from my turbo on the box."
--- yep.. probably correct.. do you want to bet big bucks before other things are eliminated.. although I always carry a spare CD and coil..
and for instance, is your ignition switch original?
" I can only assume that this is the original box('78 vintage), so it's probably seen better days."
--- maybe you can borrow a friends
" If there is no power going to the box when it dies, then it's a hunt for a short going back to the fuse panel?"
--- probably not a short
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-29-2003, 07:06 PM
canna change law physics
red-beard's Avatar
I have 2 working CD boxes (used) if someone is looking for one.
PM me for details
James
James
Red-beard for President, 2020
Old 03-29-2003, 07:18 PM
Thanks. I would bet that the box is heating up and failing after idling. It was running fine in the driveway just sitting (you could hear the whine from the box). Just as the engine compartment started to get warm, it shut off (no whine, nothing...). I don't think its a short.
Old 03-29-2003, 07:24 PM
pwd72s's Avatar
Thanks Warren! Good point, why the hell would I click to look for 1974 and up parts????
Old 03-29-2003, 08:11 PM
I put an MSD6-AL in my car. It works fine. It is harder to install than the stock unit but it is cheaper if you put the time in for instalation
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 03-29-2003, 08:15 PM
Cool
doesn"t the '74-'77 CD fit your car?...LOL ...............Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-29-2003, 08:16 PM
pwd72s's Avatar
I hate to be the guy to say this, but do a search..here and on Rennlist as well. Lots of guys seem to be very happy with MSD, if it's done right. Possibly functions better than the factory unit, assuming the right wires, coil, etc. are used.
Old 03-29-2003, 08:19 PM
pwd72s's Avatar
HOOT! Something about the number of pins? Besides, I dunno if I like the bigger bumpers they put on the '74 CD boxes...
Old 03-29-2003, 08:21 PM
Yes...I see that some have been happy. Was not sure about the turbo application though. I know it worked great in my 67S.
Thanks,
Rick '78 930
Old 03-30-2003, 04:46 AM
Rouxzy's Avatar
I just installed the msd in my '77 with big noticeable improvements. My cd box worked but had NO whine for the past two years. Go figure. When mine heated up as in real hot weather the car would lack power, it would run but more like lack luster.
Tom
Ice Green '77 Targa 3.6 w/ Steve Wong chip
One Way To Get More Horsepower Is To Get A Bigger Horse!
"I couldn't find the sports car of my dreams, so I built it myself"
Ferdinand Porsche
Old 03-30-2003, 05:48 AM
Halm's Avatar
Purely in the FWIW catagoy, Otto (Otto's Venice) hates MSD units. When he was preparing my '70 E to drive from LA to Charlotte, NC last year he removed a MSD unit and replaced it with a stock CD system.
'17 Cayenne
Old 03-30-2003, 06:01 AM
