High Hope's Avatar
Directional (Blinker) Issue-Help?
My blinkers were working correctly. Then I had my body shop install my H1s with newly painted trim rings. Then I installed the Pelican relay kit. I don't know if any of that is cause/effect, but now my right blinker works, F/R flash normally and the dashboard indicator is correct. The left blinkers both flash, but very dimly, and the dashboard indicator flashes in both directions, also very dimly.
Anyone have any ideas to offer?
Carpe Diem.
Chris
Old 04-11-2020, 09:35 AM
Rescuer of old cars
Arne2's Avatar
Sounds like a bad ground. Check the ground connection in the wiring to the left headlight and turn signal.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 04-11-2020, 10:44 AM
High Hope's Avatar
Thanks @Arne2 . I assume that the headlight assembly has to come out?
Carpe Diem.
Chris
Old 04-12-2020, 06:29 AM
