Location: behind the redwood curtain, (humboldt county) california
Quick query for you trans guys out there - is throttle pivot shaft removable??
Seriously, is that little throttle pivot shaft on the left side of a 74 mag case tranny removable?
If it is not threaded in, I will just leave it in place.
The shipping crate I built is tight and if it were out, it would give a bit more wiggle room.
UGLY crate, but stout - soon to be off to CMS for overhaul/upgrades.
Thanks,
chris
Old 11-02-2019, 04:46 PM
8mm open wrench on the end.
206 637 4071
Old 11-02-2019, 04:49 PM
I would rather be driving
jpnovak's Avatar
Yes. It unscrews from the case. Put a dowel in the cotter pin hole and unscrew.
Old 11-02-2019, 04:50 PM
Harpo's Avatar
YES, mine was hard to remove so I put a torch on the boss on the trans and eventually it came out.
Old 11-02-2019, 04:55 PM
Thanks guys, I'll try the wrench and heat.
chris
Old 11-03-2019, 07:01 AM
