915. 1-2 whine; 5-R...
Finished a transmission rebuild.
1-4 got new syncros, bands, shift sleeves, guide sleeves
Shift forks were replaced not that long ago (but lazy / rushed me didn't replace the rest of the parts I should have at the same time)
Motor and transmission back in the car and first and second gear have a funny noise that sounds like a bearing is being loaded incorrectly. Three and four are amazing. Fifth and reverse...
Let me tell you about they way they looked (fine)
the way they acted they way they had to have the color of their transmission fluid (blue)
there shifts were soft and smooth
there shifts were clean and bright
but after this rebuild...
the're not there!
5/R is just an awkward way of shifting into 3/4
I also have the wevo gate shift kit (internal to the 915 https://www.wevo.com/Products/TransmissionProducts/TransmissionImages/WEVO_915GateShift_INSTRUCTIONS_2007.pdf )
I have accepted that I am pulling the transmission and motor again. (not that I have already done this once on account of forgetting the starter ring on the new pressure plate)
What should I be looking for in the transmission?
Is there any hope of not pulling the motor/trans?
Thanks!
Andrew
Old 11-11-2019, 09:01 AM
What year car? Did you check to see if the pinion race was spinning in the case?
Old 11-11-2019, 09:24 AM
Rescuer of old cars
Arne2's Avatar
That part sounds like coupler mis-adjustment to me. I don't know if having the coupler that far out of whack could cause noises in 1-2, but I suppose it's possible.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 11-11-2019, 09:43 AM
1986 911 non turbo.
When I had it apart the race seemed ok. didn't seem loose, no heat marks...
Old 11-11-2019, 09:44 AM
Solved! The Dongle PN, 915-303-133-00 was incorrectly machined on the replacement WEVO kit. Put the original one back in, we are golden!
Also found that replacing sifter bushings was a huge help, PN: 911-424-139-00 and 914-424-224-00
Happy motoring!
Old 11-30-2019, 07:50 AM
I would lodge some complaints toward Wevo.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 11-30-2019, 10:18 AM
Harpo's Avatar
Can you please elaborate and hopefully post photos? I hope to be installing one of these and I would like to know what to look for.
Old 11-30-2019, 11:12 AM
