Drill in 6 mm studs to install SSIs?
I am about to put SSI's on my '83 SC. There are tabs to fit over the 6 mm studs on the crankcase, as in the early cars. My SC crankcase does not have these studs, of course, but it does have the bosses on the crankcase where the studs go. So, it looks like I just drill and tap, however, the boss on one side (left side, as memory serves) is awfully close to the oil gallery. Can anyone give me explicit instructions on how deep to go, and whether this is okay? The engine is a 930/10, i.e., a late Euro motor with the late (no sump plate, or removable oil pickup screen) crankcase, in case that makes a difference.
Thank you.
Old 03-31-2003, 06:01 AM
Irrationally exuberant
ChrisBennet's Avatar
I just left mine off when I had SSI's. I didn't have any problems.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 03-31-2003, 06:10 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
I would just join the two tabs with a flat bar.
That way it would give some lateral support.
Bob
Bob Hutson
Old 03-31-2003, 06:39 AM
Senior Member
Doug Zielke's Avatar
I had the same issue, Tom.
I drilled mine (nicely centered) to a little less than 0.5", then tapped the hole using a bottoming tap. No problems.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 03-31-2003, 08:17 AM
