Originally Posted by rcaradimos View Post
maybe the sensor just doesn't have the temp to get a reading.
A bit late but yes, sensor needs to be very hot to produce voltage; possible that your heater relay wasn't working?
1989 Carrera 3.2L in 993 bodywork
Old 08-03-2008, 12:19 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Tried to tweek air flow screw but it is awful tight so I didn't move it. I think I'm running a bit rich, it smells that way.
Thanks in advance.
Still getting to know her before I buy your Chip.
Bob
Hey,
My air screw was way tight, called Steve W. per his instructions, I sprayed a little penetrating oil in the screw well and gave it a couple very light taps to shock it loose. The brass and aluminum generate galvanic corrosion and that is the jam.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 03-06-2013, 07:28 PM
Originally Posted by scottb View Post
My 84 has had an "idle hunting" problem. Based upon "conventional wisdom," I've replaced the idle control valve, the O2 sensor, and the cylinder head temp sensor. Yet, the problem persists.
Does anyone have any ideas on what could be wrong? Help would be appreciated.
Scott
Has a search of this forum been done?
Old 03-07-2013, 10:41 AM
BE911SC's Avatar
Thread is ten years old. Helpful though.
'84 Carrera Cabriolet
Old 03-07-2013, 11:13 AM
Can anyone please share how to adjust the mixture on a 3.2 ?
I have a Snap-on 5-gas analyzer
Old 10-04-2020, 06:58 AM
Carl v S
carlvs's Avatar
Does the car have CIS? If so google CIS mixture adjustment screw. It’s located on top of the air flow meter. Between the rubber boot and the fuel distributor. You w8ll also need 5o adjust the idle air screw.
Old 10-04-2020, 08:05 AM
proporsche's Avatar
fuel mix is adjusted like this on 3,2 carrera
1985 911 with original 502 191 miles...808 198 km
Old 10-04-2020, 08:41 AM
Thank you proporsche
Can you post a picture of where the mixture adjustment screw is located ?
What CO figure are you aiming at with the gas analyzer ?
Old 10-04-2020, 09:39 AM
proporsche's Avatar
once you remove the plug you need 3mm allen wrench.
So,1st if you still have the plug in ..remove the afm (air flow meter)
2nd drill 2 little holes into the plug about 3mm deep so you can use needle nose pliers to remove it.(never mind those 3 punch hole that was for a different showing)
3rd to set the C/O engine should be warm and i`d would put about 1,2 without the CAT
that is all
Ivan
Old 10-04-2020, 10:08 AM
