E Sully's Avatar
Distributor Points connector
I have a couple of 0 231 169 xxx distributors. I have refreshed them to very good condition.
My only issue is the molded electrical connector. Due to age and heat the insulation is quite brittle. The newer 0 231 184 xxx and later connectors are not the same shape. Anyone know of a source for these?
Ed
1973.5 T
Old 11-13-2019, 10:22 AM
'73 911 T Targa
The closest I’ve found is to get the points/capacitor kit and remove the capacitor (unless you have use for it). It’s the closest I’ve found in order to the the connector.
https://www.ebay.com/itm/BOSCH-Distributor-Condenser-AMC-AUDI-4000-VOLKWAGEN-DASHER-JETTA-RABBIT-SCIROCCO/312032598768?epid=74964095&hash=item48a6979af0:g:OQoAAOSwKQ9aQkyF:sc:USPSFirs tClass!21117!US!-1
Old 11-13-2019, 10:43 AM
E Sully's Avatar
Thanks for that link. It is the closest thing I have seen so far.
Ed
1973.5 T
Old 11-14-2019, 08:06 AM
+1 A few years back I spent days looking for a replacement and couldn't find anything. I went with these and just cut the wire right at the plastic and put a dab of plasticoat on the end. Works perfect.
1970 911E Sportomatic Albert Blue
1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI
1973 911E Glacier Blue
1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI
Old 11-14-2019, 08:41 AM
You can carve the square ones round with a little effort.
206 637 4071
Old 11-14-2019, 09:02 AM
E Sully's Avatar
Friend mentioned he had some old VW ones in his garage somewhere. He'll dig it out for me.
I have done a little work with some electrical rubber I had. Needs a little fine tuning, but it is turning out well so far. New on left, original right.
Thanks for replies.
Also from Pelican, 356 Beru square capacitor terminal. Looks like a little sanding would round it off.
https://www.pelicanparts.com/catalog/SuperCat/14916/POR_14916_BASTUN_pg2.htm#item7
Ed
1973.5 T
Old 11-14-2019, 03:08 PM
