Chain case oil leak and cam re-timing needed?
Hi All
I have a small oil leak on the right chain case where it meets the case and was after some advice whether i can repair this without a major job of Cam re-timing as i dont have the crow foot and associated tools. I have the engine out at moment so would make sense to do it but i dont have the crowfoot tool or P202 tool or Dial indicator guage. I have read that the sprocket nut can be removed with an air gun on socket but after some advice please on this job. Thanks guys ![]()
(man/dude)
You can't really take the case off without removing the sprocket.
I suppose if you very carefully marked everything (chain, sprocket, alignment pin, etc.) and put it back together the same way you'd be close to having the correct timing. Either way I think you are going to need the crow's foot to tighten it all back to spec.
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
You cannot do this without the tools to remove the sprocket and then to retime the engine. Where are you located?
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Thanks Guys
I was afraid of hearing that! sounds like i need to get hold of the proper tools. I'm based in the UK, south east. maybe the tools can be hired? |
anyone in the UK got one of the cam nutstomski SR051 tools i can buy or borrow please?
purchase the tools you can always resell them or you could bend valve etc.
1975 911S Targa Silver Anniversary Edition |
Try a WTB in the Pelican parts classified.
Walt 82SC 3.0 81SC 3.6 |
there is a Forum "impact bumpers" in England and there is a section where you can borrow these tools
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
register and here it is
https://www.impactbumpers.com/forum/index.php?/topic/31878-special-tools-list-of-loanables/ Ivan
Invest on the right tools......
Unless you could find someone local to lend you the tools, you could either buy or fabricate your needed tools. I have been making and building specials tools for over 50 years but owning tools made by Steve Stomski is a completely different experience. Buy the tools and resell them later. You need them period. Tony |
