911SC America Horsepower Rating
It seems the consensus that the 911 SCs shipped to the U.S. were 180HP for the entire duration of that model.
However, Porsche "America" rates them at 180/188/204 (similar to the Euro variation). Engines The 911 SC was powered by a 3.0-litre flat engine, the output of which was increased slightly over the years.- MY 1978-79 - 3.0 litres, 180 hp - MY 1980 - 3.0 litres, 188 hp - MY 1981-83 - 3.0 litres, 204 hp So, are these numbers correct for the U.S. versions? Actually, my 79' Targa is noticeably quicker than my 82' SC. |
And US ones are a bit heavier than ROW.
the best SC is the early one. perfect engine setup and gear ratio.
The regular history is indeed 180, 188, 204 (though the last two don't rock'n roll) In the US emission rules may have castrated them? e.g. due to US spec reinforcements, see steel bracket next to spare wheel, inside doors and shock absorber bars behind bumper
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit Last edited by Flojo; 11-18-2019 at 01:21 AM.. |
So basically, it isn't my imagination that my 79' Targa feels quicker than my 82' coupe? I mean the Targa just feels as though it noticeably has more torque.
All US version were rated at 180 HP, but torque rating actually went up when they raised the CR for '80. Cam timing also varied, with the early US ones using the advanced timing setting. All US engines had cats, RoW did not. Take factory rating with a grain of salt. The earlier big port K-basic engines tend to have left a little more on the table with tuning. '74 and earlier exhaust, add 5* of ignition timing and richen the CIS a bit really wakes them up.
'80 RoW 911 SC non-sunroof coupe in Guards Red It's not a Carrera.... It's a Super Carrera! |
they may be called "catalysts, though they just carried a secondary airpump which is a joke.
edit: My 79 had this, 930.06. The real CAT came in late 80 (correct me if I'm worng). Quote:
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit Last edited by Flojo; 11-18-2019 at 10:57 AM.. |
All US SC have catalytic converters, the cats become more sophisticated 3 way cats in 1980. These can be id'd by the O sensor just before the cat inlet and separate control computer under the passenger seat and the frequency valve on the fuel distributor to control fuel pressure and new fuel distributor w/ line connection to the frequency valve and throttle switch and the integration of the temp sensor in the right timing chain cover
Still here
The 204 HP model is the late Euro SC, which had the early SC large ports and runners, but instead of 8.5/8.6 CR, had 9.8. The comparable US model had the smaller ports/runners, and 9.3 CR., and less advertised HP.
Cats etc would vary the actual HP numbers as well, but headers and the rest of the exhaust are the kind of things easily changed as external. If you put the 9.8 pistons into an early SC, you get the Euro power output. |
My 1979 SC ROW went well. I was very happy with it. But it got one or two broken headstuds. Young Reuben, Big Reuben and Dave at Powerhaus said they will put in my spare 1982 SC ROW engine with SSIs and cam job into the car.
Not as much low down torque. But it really rev's out. A lot faster overall. I tend to keep the rev's up anyway, so it suits my driving style. Definitely a better engine. |
