getting ready to remove injectors: help
I'm getting up enough courage to remove the injectors for cleaning. I think I've identified all attachments to remove the fuel rail. Am I on the right track? Any help is appreciated.
Old 11-17-2019, 09:42 PM
Yes the fuel rail is a loop drivers side is the feed. do your filter while your in there
Old 11-17-2019, 11:11 PM
I just did mine but did not have to undo the rear fuel line connections to the rails. I undid the front and the rail mounting bolts and other stuff like the left side connector bracket then just tilted it up at the front and disconnected the connectors and wiggled out the injectors. Mine came out easy and I had Mr Injector service them.
Did the filter at the same time
crude rudy
'84 cab
'14 ZX-14R
Old 11-18-2019, 07:18 AM
Thread Killer
Teutonics's Avatar
Make sure to squirt some PB Blaster or other slippery oil at the base of the injectors (where they fit into the intake) before attempting removal. Makes pulling them out MUCH easier!
Allen
'85 911 Coupe
'75 BMW 2002
'02 Ducati Monster 900ie
'18 GMC Sierra Denali 6.2L 4wd
Old 11-18-2019, 07:36 AM
Have noticed the speed and reference sensor wires in your one picture... the two silver ones on left hand side (see your disconnect D3 arrow)... the exterior insulation is totally worn off exposing the silvery wrapping underneath. You may have noticed crumbled insulation in the engine compartment from them. You may want to replace those sensors along with the O2 sensor when you get a chance....they're old..... don't want to get stranded some day. Big cause of "no start" problems with an older 3.2.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 11-18-2019, 07:50 AM
Thank you everyone for the tips. Well, I was able to remove the rail with injectors. I don’t see a metal clip holding the injector. Am I blind? Should I just pull the injector away from the rail? I’m getting close! Thank you for the help.
Old 11-20-2019, 08:37 PM
Removal complete!
Actually wasn’t that bad. These injectors look like they could use some love.
Old 11-20-2019, 10:46 PM
The 9 Store
mrinjector.us
great service!
Old 11-21-2019, 06:24 AM
Clips AWOL?
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 11-21-2019, 06:38 AM
Thread Killer
Teutonics's Avatar
Yeah, your clips are missing... you'll need to order a set for reinstall.
Allen
'85 911 Coupe
'75 BMW 2002
Old 11-21-2019, 06:43 AM
Originally Posted by jlex View Post
Clips AWOL?
Who needs them. Fuel rails bolt the injectors down so they have nowhere to go. Got rid of my clips years ago when I realized how silly they were.
Cheers,
No Clips Joe
87 Carrera
Old 11-21-2019, 07:08 AM
Thread Killer
Teutonics's Avatar
Cheers,
No Clips Joe
87 Carrera
Good point... I hadn't thought of that. Although they're nice for removal so they all come out as an assembly, if I broke or lost one, I probably wouldn't be concerned about it when reassembling... except that I'm totally anal-retentive and I wouldn't be able to sleep at night thinking about it! LOL!
Allen
'85 911 Coupe
'75 BMW 2002
Old 11-21-2019, 07:22 AM
Keep us posted on what you learn in regards to the condition of your injectors and how much improvement you notice after the service. Am considering doing the same with mine - 1985 model year.
Yours,
Dave
1985 Carrera 911 Cabriolet - Grand Prix White / Black interior and top.
Old 11-21-2019, 07:51 AM
Wildman Emeritus
Will any AFM adjustments need to be made after reinstall/replacement?
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 11-21-2019, 08:16 AM
Those injectors don't stock. What's the Bosch PN eg. 0 280 150 ...?
Joe
Old 11-21-2019, 08:36 AM
carreradpt's Avatar
Hunter, would you please explain your process you followed to remove them. Take any pics of the rail removal?
Dan T
'85 Carrera
Dansk premuff/sport muffler
7's and 8's, Steve W chip
Kuehl AC and fresh top end
Old 11-21-2019, 11:52 AM
