Clocking of clutch release fork
I was hoping this would be obvious when it came to put the parts together, but it isnt.
#1 Release fork is splined to the shaft #2
#13 Clutch released lever floats on the shaft (non-issue)
#18 Change Lever is also splined to the shaft.
I assumed that I would clock #1 and #18 in line with each other, but in that configuration #1 Release Fork would have very little travel to release the pressure plate.
This alignment of #18 makes the most sense, red line is approx position of #1.
There must be a correct way to set this up, but I have found nothing in the Pelican search history or Bentley manual.
Appreciate any pointers!
1978 SC Targa
Old 11-21-2019, 11:07 AM
proporsche's Avatar
your solution is very simple;-) remove the clutch arm and the little finger..After you install engine and trans....then install the arm and little finger + spring .Also do not forget to use the seals..number 4 ,one inside and two outside....you see simple...
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 11-21-2019, 11:15 AM
Appreciate the reply, Ivan.
So when the #1 release fork is held in position by the throwout bearing will there only be one logical position (clocking) of the #18 Change Lever? Or do you just select the rearward most position to get the maximum travel?
1978 SC Targa
Old 11-21-2019, 12:17 PM
proporsche's Avatar
Once you have the all in the car.Hook the clutch cable to the arm and pull towards the back of the car with a big screwdriver to power over the Omega`s spring tension.The you instal another seal and little finger with the spring.leave a play in it..Adjust your cable to the specs-there are more then one link in here - i`m sure you can find out.After your clutch is adjusted adjust the play on little finger...that is all...Oh ya lube everything.............
Ivan
Old 11-21-2019, 12:41 PM
Makes sense...
Regarding the seals, I have two o-rings and one shaped seal. I'm guessing the shaped seal goes on last with the small arm #18 (yellow), and the o-rings go where marked green. Does this look correct?
1978 SC Targa
Old 11-21-2019, 12:48 PM
proporsche's Avatar
those 3 seals should be the same..
Old 11-21-2019, 01:05 PM
Looks like the Elring 915 trans gasket set only provides one of those shaped gaskets. I'll order a couple more separately.
Thanks again for your help Ivan.
Matt
1978 SC Targa
Old 11-21-2019, 02:50 PM
proporsche's Avatar
u r very welcome.
Ivan
Old 11-21-2019, 02:54 PM
