safe's Avatar
Alternator stoped charging
Hi
My car, 1977 targa, has stoped charging. I just see 11.4-11.5 volt on the battery.
I don't think it has stop charging totally because I have driven it quite long distances and I don't think the battery would have survived that.
The alternator light in the dash isn't on either.
Is it the regulator or the alternator, what is really the best approach testing this?
Regulator: The stock mechanical black plastic regulator (tries adjusting the screw on the bi-metal, did nothing)
Alternator: Stock from a 72 car (55amp? something) It was overhauled 10 years ago when I built this engine.
Magnus
Old 11-22-2019, 05:10 AM
It can be as simple as the indicator bulb in the instrument. It is required to excite the alternator to charge. If it is burned out the alternator will not charge. Check that first, it is real easy.
Old 11-22-2019, 08:16 AM
76 911S Targa
Alternator Not Charging
The other place to look is at the 14 pin connector. Since you have no dash alternator light, either the connector has lost electrical connectivity through corrosion or vibration, or the light bulb is broken. Good luck.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 11-22-2019, 08:29 AM
