Lowering my 1970T: Easy??
How easy is it to lower my 1970T? Will I need a re-alignment afterwards? Thanks for your reply...
To whom it may apply (Wayne), If you're going to micro-manage your BBS, please enforce your rules consistently...I understand your concern about keeping OT posts in the OT bin, but how in the world can you make a judgement on whether it's "blatant" or not?....I've been a Pelican Parts customer many years now and suspending my account for a day is a bit childish, dont your think. It's like 3rd grade where you go in the corner for 5 minutes for throwing chaulk....thank you for your understanding. -Faithful User
Id say its about setting an example its his deal I guess you have to respect that
72 911 82 911 70 GTO ![]() 97 GT Ragtop 74/76 Jeep cj's |
Back to the original topic. Lowering the front is pretty easy, doing the back is a nightmare. Its all about getting the splines right on the torsion bars. If you have an early car and want to lower it, i think you will come out ahead if you invest in a set of adjustable spring plates and DIY. I have a 1970 T also and the once you get the adjustable ones you can raise and lower it to your taste.
If you do lower it, i would have the alignment checked at least. Paul
My ignition is retarded. |
It's actually not hard at all if you get an angle finder and use Wil Ferch's calculator. The real problem is "while your are there" syndrome.
Neil '73 911S targa |
what is the current ride height? I know "euro-spec", so I'm curious as to how low "I got banned so I signed up under an assumed name so I could complain" measures up.
