Door alignment correction - easy fix?
The passenger door on my race car (1970 tub) sits a little proud - anyone know what is involved in adjusting it? Is this a job better left to a body shop?
Cheers - Ryan |
It is not hard to fix. Depending on where it is sticking out, adj. the hindge or latch so the door fits better
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
I would rather be driving
door alignment is determined by three points. Upper and lower hinge, rear latch plate.
to move the door back, insert more shims under hinges. to tilt the door remove/add shims under hinges. to move door in/out, adjust hinge for front, latch for rear. Its pretty simple. Don't forget to buy the correct 12pt star tool to move the bolts. An allen/hex key will strip it.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
