Author of "101 Projects"
Ok, I'm querying a whole bunch of people on this topic, trying to come up with a recommended list of engine combinations. Here is the intro to this particular section in the book:
Wayne’s Top Engine Picks Okay, you’ve read this section, and you’re all excited about rebuilding your 911 engine, and extracting some more performance out of it. However, you’re still confused as to exactly what you need to do to get the engine performance that you want. In this sub-section, I have polled quite a few Porsche engine rebuilding experts, and have generated the following table of engine recommendations, based upon the performance characteristics you may wish to extract out of your 911 engine. Keep in mind that these recommendations only represent a small sub-set of what you can do. With a custom crank regrind, custom-designed JE pistons, and even a custom-programmed engine management system, there really is no limit to the number of variations that you can achieve. ------------------- Okay, what does everyone here recommend based upon their own experiences? -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
I've only rebuilt 1 porsche engine, so not sure if this counts but here goes. Started with 72, 2.4T motor. Installed rs pistons and kept the T cams as stated by Anderson. Great torque, but wasn't satisfied. Took cams out and had them ground at what was at the time called a slalom grind-whatever that meant. Even more torque w\ more mid range. Still not satisfied, so I put in E cams and am very satisfied with the over all power band. Had pump rebuilt by pacific fuel inj. Installed stock head studs which after 40,000 miles are still going strong. Plus did all the goodies that one is suposed to do.
That's it. Still runs great and that's after very hard driving Can't wait to hear all the reply's by the TRUE engine builders.
72 911 Although it is done at the moment, it will never be finished. |
Crotchety Old Bastard
930:
K27-7200 Turbo 1 bar wastegate spring SC or 964 Cams C2T sized Intercooler Aftermarket Heat Exchangers or Euro Exhaust This is a 100 horsepower upgrade that is commonly done.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
93 up 964 or 993 in a 89 or earlier chassis, B&B headers
Sorry, engine swaps don't count...
![]() -Wayne
Darn!!
Senior Member
I would say the tried and true:
2.7 Euro RS pistons/cylinders S cams light flywheel Webers or MFI When this comes on cam there is no other sound or experience like it.
Visit the Virtual PORSCHE Rennsport Reunion Tour |
1-6-2-4-3-5
A short-stroke 3.2 (98mm bore x 70.4mm stroke) with GE80 cams, headers, and a set of Weber (or even better, PMO) 46IDAs makes a very strong engine that loves to rev. It's probably my favorite 911 engine of all I've driven, and it's built from a common SC. It's also a tried-and-true combination so you don't have to worry about piston-valve interference (though it's still a good idea to check that when you build it). The idle is lopey but insane people like me could tolerate it on the street. And talk about useful track power when combined with a short ratio 915... pulls like a freight train from 6000-8000 RPM and wants to keep going! Ah, I miss that motor. Now we've taken it apart a built a scary 3.4 with it and I must admit I'm a little timid about pushing this new one, though I imagine I'll gain confidence with it once I get a chance to run it on track. Sure sounds mean though.
Oh, by the way, the 3.2 short stroke combination above dyno'ed at 305 crank HP on race gas, single plug. You'd probably want to twin plug it and be conservative with timing to run it on pump gas. zuff |
Hilbilly Deluxe
Tom |
1-6-2-4-3-5
zuff |
tell me more about your engine...I am planning something like that...did you switch the crank to a 3.2L 74.4?
I have been thinking of a long stroke 98mm or 100mm.... |
1-6-2-4-3-5
Regards, zuff |
You can post details here, I'm curious...
-Wayne
It's my recommendation that anything over about 9.8:1 should be twin-plugged. You'll be able to run it better on pump gas, and you won't blow it up from detonation. That sounds like a good engine, but it does sound like it's missing the twin plug...
-Wayne
Ive modifide my first and only P car and love it after driving it stock for about a year.
75S with a 2.7. I did as much as I could afford from B.A.'s book: Webers, polished ports, Solex cams, and headers. This required eyebrowing the pistons. And then the standard "no gain- must do's", time certs, raceware studs, oil fed tensioners, 11 blade fan, electronic points. This gives a great midrange punch, and sounds so cool when its opened up. Im still going with the stock muffler. Ive been reading all the posts I can on muffler choices and nothing seems like its what Im looking for yet. |
As for the new 3.4 my father and I built, it came to be as a result of a 915 gearbox breaking under full load at Summit Point Raceway in WV. When the gearbox went, the 3.2 was zinged as well and all the valves were bent. Up until that time, the 3.2 had been a powerful and bulletproof engine for several seasons. The car races in PCA's GT-3S class for which the displacement limit for a naturally aspirated engine is 3.4 liters. So since we had to take the engine apart to fix it anyway, we decided to build a more powerful 3.4 liter engine. The new engine uses a 74.4mm Carrera crank, Pauter rods, and JE pistons which retain the 98mm bore. The compression ratio is 12:1. We had the heads repaired and twin-plugged. We're still running the GE80 cam which should work well, but a GE100 would probably be a better match for the larger displacement. This is a race engine only, thus my hesitation in including it in this thread, though I'm glad y'all are interested as I am very excited about it. As for building a 3.4 street engine the same way, by substituting a 74.4mm crank and using Mahle 98mm pistons & cylinders, I'm sure it would make a nice street engine as well. It's just that the short-stroke 3.2 is much cheaper to build (the 74.4 Carrera crank alone cost us over $1500) and really likes high RPMs. I imagine when we'll eventually spin this new 3.4 to 8000 RPM too, but I'm just honestly not as confident in the Carrera crank as I am in the SC crank. The short-stroke 3.2 is just a great combination. Oh, one more thing about doing a 3.4: there are distributor issues to consider when you change to the Carrera crank. You either need to swap drive gears before you put the crank in, or you need to get a clockwise distributor. My father and I found that out the hard way when we tried to put the distributor in the new 3.4. Yup, we had to tear it back down all the way to the crank, change the drive gear, and build it all over again. We had already spent the $$$ on the twin-plug distributor, so redoing the engine was the best solution. There was a lot of profanity when we figured out why the distributor didn't fit. I never have figured out why Porsche decided to change the way the distributors run on the SCs. Regards, zuff |
Senior Registered User
My idea of fun.
Motor:
1983 SC 3.0 95mm x 70.4mm Bored and sleaved cylinders to 98mm 3.2 liter 10.2:1 J-E pistons Web-Cam #120-104 grind 3.2 Carrera heads, upgraded springs/retainers,dual plugged PMO 46mm carbs w/ tall manifolds Dual plug 964 distributor conversion to mechanical advance ARP rod bolts Carrera pressure fed chain tensioners twin MSD 6AL ignition boxes 930 lower valve covers Elverude aluminum flywheel Sach aluminum pressure plate SSI heat exchangers S-CAR-GO Racing dual in/out stainless steel muffler 281 HP-244ft/lbs torque @ 6700 RPM on PUMP GAS Gear box: 1983 SC 915 ZF LSD Factory short shift kit 8:31 R&P 1st gear / 11:35 ( stock ) 2nd gear / 17:34 ( down three ratios ) 3rd gear / 21:29 ( down two ratios ) 4th gear / 25:26 ( down one ratio ) 5th gear / 38:30 ( stock ) I have bought throttle bodies and in the near future will add EFI. Randy Jones 1971 911 BTW- This is just one guys idea not saying it is correct for anyone but ME. |
OK, MY dream engine, here it goes:
Start with a 3.2 Carrera Engine platform and add: RUF 3.4L Turbo P&C's (7.5:1) RUF Lightweight Titanium Rods ARP Rod bolts & head studs 964 Piston Squirters 964 Oil Pump Twin Plugged heads Extrude honed intake manifold & ports GT2-Evo CAMs Flame ringed cylinders/heads with Aluminium sealing ring 944t Injectors Motec/Autronic Injection (Pressure Sensing) Twin T3/T4 Hybrid turbochargers Twin TiAL 40mm Wastegates Dual in/out free flowing muffler Electronic Boost controller set to max of 1.4bar Custom 900+ Cubic Inch Intercooler Hmmmm - should be good for 600+ HP
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Hmm, indeed these are very cool setups, but they would probably be very difficult to drive on the street.
Anyone with a driveable car (that's not crazy?) -Wayne
