Got Boost?
IMONBOOST's Avatar
Rebuilding your own starter?
Has anyone tried rebuilding your own starter? I have a CLYMER Repair Service Book and it expleins how to go about this. Is this really worth it? Are the brushes and other parts available out there? Looking at the book it seems pretty simple, not a $240+ job.
"The only motivation to make you go race after race, travel after travel, is winning. The possibility that you have for winning. If you don't have that, nothing else can make you work."
-Ayrton Senna-
Old 04-01-2003, 05:16 PM
Early_S_Man's Avatar
Porsche Crest
Yes, several times. Bushings, and brushes are readily available.
Be sure to use a high-quality, high-temperature moly grease such as Valvoline #986 SynPower Synthetic Grease with Moly on the bendix mechanism, solenoid plunger and linkage! Clean everything thoroughly with Brakleen or a similar solvent before lubing and reassembling.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 04-01-2003, 06:18 PM
Gordo2's Avatar
Rebuilt Starters
I had the starter on my '87 Landcruiser rebuilt at an electronics repair shop that specialized in rebuilding starters and alternators for around $50.
Check the yellow pages, for that price I couldn't afford to goof around with it.
Would look into the same if the starter on my car went bad.
Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 04-01-2003, 07:02 PM
Is it possible to just replace the toothed gear at the end of the starter? My starter is relatively new but the teeth are a little more worn than I'd like due to the fact that the starter ring was getting worn, resulting in the occasion poor connection and slightly chewed up starter gear. I'd prefer to not completely replace the starter on top of the cost for the current rebuild I'm doing.
TIA
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 05-01-2008, 03:39 PM
I would recommend you find out what shops that work on starters would charge you. I have a Hi-Torque starter and it was $65 to rebuild w/a 1yr warranty 11months later I took it back and they fixed/replaced the solenoid.
same day service, if they have the starter before 9am I can have it back by 2pm
fix.
It would probable take me longer, and I don't always have the extra time.
carrue529
1987 911 Carrera
S.Wong chip|ElginCams|GT3 oil pump|short gearing|Guard TB-Diff|22/29 Hollow T-Bars|monobloc calipers|Bilstein HD/Sport|Turbo tie rods|Strut brace|CobraMonza II seats|7, 9 Fuchs|Elephant polybronze bearings F/R|Wevo eng mounts|bypass cat pipe|M&K muffler
Old 05-01-2008, 05:40 PM
AutoBahned
RWebb's Avatar
TIA
yes search for my post on this - try pinion + starter + gear
Old 05-01-2008, 05:41 PM
