No way would I attempt removal in 'situ...too much of a wrisk.
BEST! Doyle |
Yeah, it took 140 Psi to get it out of the block...http://forums.pelicanparts.com/porsche-911-technical-forum/594895-stuck-oil-pressure-sender.html
In the meantime
The sender was bad, full of rust, no way it can meassure something.
I order the new sender, unfortunatelly it takes a month to get to my country. I meassure the preassure and was OK (15 to 65 PSI). In the meantime, I built a plug out of the same sender unit (see picture). Definatelly, I'll address the torque issue when istalling the new sender unit. http://forums.pelicanparts.com/uploa...1356379811.jpg |
DO NOT put a lot of torque on that sender while it is in the car! As the poster above suggested take it out and put the brass block in a vise and then remove the sender. |
| All times are GMT -8. The time now is 12:46 PM. |
