porsche_virus's Avatar
Need to indentify this brake caliper...
Okay guys...this should be a simple one for you brake gurus. I need to order a full set of caliper rebuild kits, but don't know if I have "M", "S", or "A" calipers. This is the front right caliper. The car is a stock '74 911, 2.7 CIS. Hopefully someone can identify the model by this pic:
Old 04-02-2003, 06:16 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
is that off the rear or the front?
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 04-02-2003, 06:20 AM
JWest's Avatar
Looks like an "M". Measure the spacing between the mounting bolt holes - 3" is definitely an "M".
James
JWest Engineering
Old 04-02-2003, 06:35 AM
Glasgow 911SC's Avatar
Looks like an 'A' caliper fitted to the fron of 911s from early 70s through to the SC. Carrera used same but with spacer for thicker disks.
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 04-02-2003, 06:36 AM
Yep...3" between the mounting holes, so I guess it's an "M"! Thanks guys!
Old 04-02-2003, 07:13 AM
Targa Dude's Avatar
Send a message via AIM to Targa Dude
Do you have a Magnet handy? go steal one off the Fridge..
if they are magnetic, their "M's" If not their S Calipers.
Jorge (Targa Dude)
Old 04-02-2003, 11:03 AM
Send a message via ICQ to old_skul
It's an M.
Mark Szabo
1986 911 Targa 3.2 (I will miss you)
1985 Scirocco 8V (I will not miss you)
1986 Dodge B150 Ram Van (I can't believe I got $200 for you)
1987 Escort 5-speed 1.9 RIP
Old 04-02-2003, 11:29 AM
Guardsred911's Avatar
Resurrecting this old post.... trying to identify my front caliper from a 77 911S with CIS. bolts holes are at 3.5 inch centers and it's magnetic. A Type?
J
911 SC - 1980
911 S - 1977
Old 11-09-2019, 11:20 AM
(man/dude)
Jonny042's Avatar
Gonna say yes. Check out:
https://www.pmbperformance.com/mid-911-brakes.html
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 11-09-2019, 11:57 AM
Yep "A" caliper
Old 11-09-2019, 01:11 PM
Troll Hunter
While we're talking calipers, my caliper pistons are frozen solid in my M's. I don't have a large air compressor to pressurize them outwards, just a small one.
Any suggestions?
1978 SC Coupe, Gris Argent Metallic Silver
1988 FJ62 Blue/Gray
2020 M2 CS
Old 11-09-2019, 01:28 PM
Registered Minimalist
75 911s's Avatar
Small one will work. You have to plug the bleeder hole or any other holes. It doesn't take much at all unless they are completely frozen via rust.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 11-09-2019, 02:24 PM
The 9 Store
A grease gun will also work.
Old 11-09-2019, 02:57 PM
Thanks! Will report back....
J
911 SC - 1980
911 S - 1977
Old 11-09-2019, 06:50 PM
Here are a few picts after I pulled the caliper apart. The fluid looked terrible. A little corrosion, but nothing emery cloth can't fix.
I also recommend using a board between the calipers when using an air compressor to push the pistons out. the corroded side would have been stuck in there, and the cleaner of the two would have come out easily.
J
911 SC - 1980
911 S - 1977
Old 11-10-2019, 01:10 PM
Troll Hunter
You split the caliper? You're a braver man than I. I pray for no leaks after reassembly.
I spent two hours at a friends house today trying to get four pistons out of my 2 rear calipers (1972 T). Each one was more rusted/frozen than the next. We attempted to push them back in further a smidge with a C clamp each time, PB blasted them, and then applied 100+ PSI through a jury rigged brake line to get them to move outwards. Each one took several back and forth processes before finally BANGING/POPPING outward. It was a little scary how powerfully they come out.
It wasn't easy, but we won.
BTW, Centric has ZERO M remans anywhere in the country. Why is that?
(BTW, how did you get your calipers so clean?)
1988 FJ62 Blue/Gray
2020 M2 CS
Old 11-10-2019, 05:56 PM
Vintage Owner
Jack Stands's Avatar
I’ve taken to simply send mine to Eric at PMB as they come back cleaned, rebuilt, and replated in a rapid time. Often he has calipers already ready to send out (with a refundable core charge), or can turn yours around quite quickly.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 11-10-2019, 06:26 PM
Thanks! Brake Cleaner and a brush....
J
911 SC - 1980
911 S - 1977
Old 11-19-2019, 02:57 PM
Cleaned and ready to assemble.... parts arriving tomorrow... cleaned using a wire brush, wheel, pick, and #000 steel wool.
J
911 SC - 1980
911 S - 1977
Old 11-29-2019, 06:51 PM
Success.... works like a champ.... now, onto the other side...
J
911 SC - 1980
911 S - 1977
Old 12-20-2019, 02:45 PM
