Front Strut Mounts
Anyone else replace these as a wear item? I have the originals but since they are 32 years old I'm wondering if they help with ride quality and handling...
1987 Porsche 911 Carrera - Lagoon Green |
Any rubber bushing will wear in time... especially after 32 years.
From a priority point of view, the top strut mount bushings are the least "important" compared to other bushings for good handling. You get two-piece inserts on the market to refurbish the mount after cutting out the factory one-piece rubber. Taking the mount out though will require a re-setting of camber and toe.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
Likewise if the upper mount has obviously failed, then you probably would replace the rest of the rubber bushings since they won't be far behind and you can then do a single re-alignment. Mark
1979 911SC Targa |
