Custom Door Handles
Hello,
Does anyone know the source for these door handles? Are these made by Accumoto or do they just adapt them in to their builds?
Ed
Old 12-19-2019, 03:25 PM
Many 911s have custom door handles from other models. I’ve seen some with fiat, vw even 356. I found some I liked at a swap meet recovered them and fitted them to my custom door panels.
78 911 st backdate
87 944
00 996
Old 12-19-2019, 04:21 PM
I'm good with tools.
AG81's Avatar
Would these work for you...?
Just flip them over........
https://www.tmiproducts.com/volkswagen/karmann-ghia/1965-ghia-coupe/accessories/left-armrest-off-white-1955-67-bug-ghia.html/
There is a Left & Right.....
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
13 991.1 Coupe 2S 3.8L (currently undergoing mods)
02 996 4S
Old 12-19-2019, 04:44 PM
For my project, I want to be able to bolt to the metal in the door,
For the the Karma Ghia and VW bug handles shown above, how do they install? I found some pictures of the handle installed on the door card itself before it gets installed on the door. Would like to avoid installing on the door card. What was your solution?
On my original post, the door handle is secured with external bolts.
Ed
Old 12-19-2019, 05:31 PM
Mine are bolted to the doorcard it’s 3/16 plywood so it’s plenty stiff and strong enough.
78 911 st backdate
87 944
00 996
Old 12-19-2019, 05:50 PM
AG81's Avatar
X2 very stiff and strong......(insert inappropriate comment here)
02 996 4S
Old 12-20-2019, 08:06 AM
Ed
The VW door pull handles have a metal bracket at the inside of the door card held by the bolts that hold the pull handle the door card is sandwiched between the handle and the bracket this bracket slips over a metal raised tab on the door skin so that the door card is not pulled against the bracket and the door tab take the pulling foce
Old 12-21-2019, 02:58 AM
Imoto, thanks for the insight. I may be able to incorporate that idea in my application.
Old 12-23-2019, 11:10 AM
