RallyJon's Avatar
Thumbs up Replaced two batteries with one today...
One or both of the two Interstates quit, and they both looked pretty bad. I got a WestCo Miata battery, which is the completely sealed absorbed glass mat type. I've had the same type in my Subaru, where it's cranked 2.5L and 10:1 compression, so I figured it could handle 2.4L and 7.5:1 compression without too much trouble. It fits easily in the stock boxes, and is shallow enought to fit flush. I spaced it out with foam so I could use the stock strap. It weighs 24lbs and cost $85 delivered.
I replaced the main battery cable that goes around the gas tank with a much shorter one straight across to the fuse block. This terminates in a simple aluminum distribution block, which connects to the starter cable and the other three small cables with a free port left over for future installation of headlight relays or a decent horn.
993 · 911 · STI · S4 · rally car
Old 03-29-2003, 06:09 PM
HarryD's Avatar
Very nice! When my two dudes quit, I may do something like that.
Why did you place the battery on the passenger side? My preference would be to place it on the driver side (weight distribution be damned) so's i can put all of my tools and emergency parts next to my spare tire.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 03-29-2003, 07:06 PM
RallyJon's Avatar
For corner balance. Without the spare (fit-a-flat in smuggler's box, AAA card in wallet, rally car trailer in a real pinch) there's not too much left holding the right front down.
On the other hand, I do a pretty good job holding the left front down. When I lose 48lbs, I'll move it over to the driver's side.
Old 03-29-2003, 07:43 PM
CamB's Avatar
This has inspired me - I'm going to:
1) Get a battery tie down (I know - its dangerous without!)
2) Put a distribution block in the drivers side box - I have only 1 battery but the POs bodgy wiring needs tidying and this is the impetus
RallyJon - maybe put something over the positive terminal - its is pretty close to the metal and something could fly around and you'd get a good spark show under there...
1975 911S (in bits)
1969 911T (goes, but need fettling)
1973 BMW 2002tii (in bits, now with turbo)
Old 03-30-2003, 02:41 AM
techguy's Avatar
Porsche Crest Battery
Looks like a great idea, my single battery quit just this week and I was looking for a better solution then a non tied block battery floating beside my spare. Do you know if WestCo has a battery with side termainals? Maybe a better option to offer some more space to prevent a +'ve to ground connection via top terminals? Do any other companies manufacture similar batteries? I need all the options I can get here in Toronto
Pete
TechGuy
1972 Targa 911T/S 2.7
PCA Upper Canada Region
Old 03-30-2003, 06:09 AM
lagrassa's Avatar
Rally John:
Just read your post on the batteries. My two Porsche-brand batteries needed replacement and I couldn't find anything to fit the boxes, so I got two more Porsche-brand batteries. Very expensive. For future reference, what is the Interstate Battery part # for the ones you had and what is the manufacturer and part # for the single one you replaced those with? As long as they fit the boxes, it's fine. For originality's sake, I think I will keep the two battery set-up until I get too frustrated with it.
Thanks.
70 911T Targa
My pics here: http://www.flickr.com/photos/lagrassa_michael/sets/72157618019451499/
Old 03-30-2003, 07:32 AM
RallyJon's Avatar
They were Interstate "U911-50"s. Here's a link: http://www.ibsa.com/Batteries/ProductLines/AutomotiveTruck/ProdLine_U911-50.htm
The Miata battery is from here: http://www.westcobattery.com/miata.html
Old 03-30-2003, 12:15 PM
lagrassa's Avatar
Thanks for the info Rally Jon.
70 911T Targa
Old 03-30-2003, 01:28 PM
skinnerd's Avatar
RallyJon:
How far did you have to space the battery out from the rear wall with foam? I like what you've done, but may install a more rigid false rear wall as I do quite a bit of autocrossing/track events with my car. Thanks
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 04-01-2003, 04:54 PM
RallyJon's Avatar
Oh, about this much:
That's 1/2" thick foam. The battery fits completely in the box, but the strap won't work. Eventually, I'll remove the stock strap and fabricate one to hold it in flush.
Old 04-01-2003, 06:13 PM
304065's Avatar
I'd put a piece of wood over the top of the terminals, or better yet, plexiglass-- a good bump and new meaning to the term "ignition points."
I recommend the "Optima" battery used by car audio types, not cheap at about $225 but totally sealed, lightweight and cranks like a madman. www.sounddomain.com
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 04-01-2003, 06:31 PM
RallyJon's Avatar
I got vinyl covers for the terminals, but something covering the metal on the top inside the battery box sounds like good insurance. I guess I could just rivet a sheet of plastic up there...
Old 04-01-2003, 06:40 PM
Jon,
where did you get that aluminum distribution block? how much was it etc.
also, thanks for that site you have up. I recently used it extensively to instal some carpet I also got from OFI. OH that reminds me. mine came w/o kick panel pieces. need to call him.
Old 04-01-2003, 06:48 PM
RallyJon's Avatar
I got the distribution block from McMaster-Carr, but you can get them at any car stereo store. It was about $15, I think.
Glad you liked the site!
Old 04-01-2003, 06:50 PM
HarryD's Avatar
For what it is worth, my car was lacking a battry hold down so I had a sheet metal guy I know make me one. It looks like this:
Harry
2020 MB E350 4Matic
Old 04-01-2003, 06:51 PM
HarryD's Avatar
Originally posted by skinnerd
RallyJon:
Doug,
If you need to get some spacers, go out the facilites group where you work and have them give some scraps of plastice PVC Pipe. You can cut them to length and glue them together to make a nice, rigid corrosion resistant spacer.
Harry
2020 MB E350 4Matic
Old 04-02-2003, 12:08 PM
