IAN IAN is offline
What should the Point Gap be for a 72 2.4 T?
A few quick ignition tune up questions:
1) what should the point gap be for a 72 2.4 T
2) Is it necessary to lube the points anywhere?
3) How about distributor lube?
Thanks,
Old 04-02-2003, 11:55 AM
Early_S_Man's Avatar
Porsche Crest
1. 0.014"/0.35 mm
2. Lube the cam & rubbing block with Bosch grease
3. SAE 20 engine oil or 3-in-1 oil on the felt plug under the distributor rotor
Full '72 - '73 spec book data & discussion here:
distributor lube...
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 04-02-2003, 12:06 PM
