Whats this wire in engine bay?
Car runs fine, but whats this wire in the engine bay? Passenger side, runs along the side to rear corner. Nothing nearby that it looks like it was connected to.
1970 911T/S coupe Irish green
2013 991 coupe aqua blue sold
1978 911SC Targa Venetian blue/cork sold
Old 12-30-2019, 04:52 AM
ground for oil tank ...
Old 12-30-2019, 05:33 AM
Thanks thats what I was thinking! Now to find a place on the frame to put it.
Old 12-30-2019, 05:39 AM
proporsche's Avatar
also i would check on your engine mounts ,they seem pretty worn out;-)
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 12-30-2019, 06:37 AM
Phrog's Avatar
Grounds are colored brown. It may be the oil tank level sender wire. Does it have any color other than green?
Kevin
84 911 Carrera
71 911E Vintage Race Car
25 Ford Explorer ST
20 Subaru Crosstrek
Old 12-30-2019, 07:19 AM
madcorgi
Guest
Posts: n/a
Maybe some sort of connection to the AC, which has been removed from your car? Is the wire hot?
Old 12-30-2019, 07:43 AM
Yes it had AC but that is now removed. I'll check if there are any other colors or if its hot.
Old 12-30-2019, 07:48 AM
That was my thought as well.
As a general rule, the Porsche factory used brown wires for grounds. That green one is likely the sender wire, or something else. It does not look right for a ground.
Old 12-30-2019, 12:44 PM
it is the power supply for the A/C
Lorne M.
83 SC
Old 12-30-2019, 04:47 PM
It is green only. Tested the wire with the engine running and got no signal. AC controls are removed as well so not sure if it needs to be turned on to be hot.
Old 01-06-2020, 10:42 AM
ROW '78 911 Targa
timmy2's Avatar
A/C wire runs through the tunnel to dash/console or other switch control area.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 01-06-2020, 01:20 PM
