Wheel lock or key help
Hey just picked up a new 77 911. The dumb nuts I bought it from didn’t send me the wheel lock and can’t find it. Can’t seem to find one online at all. Any tips?
Pic of wheel lock
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Wheel locks.
Do a search "wheel locks".
It might be "Dremel time chisel time". I have a set somewhere. Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Dealership may have a master set and could remove themand I have seen a removal socket at autozone that may work to remove them
https://www.autozone.com/test-scan-and-specialty-tools/stud-remover/cta-3-4in-emergency-lug-nut-remover/453073_0_0 really the only person those are stopping from removing your wheels is you, a thief is likely to take the whole car
I think that maybe I'm dreaming.. Last edited by 964TargaC2; 01-12-2020 at 11:52 PM.. |
Exactly. Yeah I’ve searched online and ran by autozone and oreilly with no luck
Their are reversed helic tools available that you will need to use with an impact driver. No mater, will be a pain in the ass. Bob
use a pipe drill bit..do it slow ...........it works
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
yes that is the one;-) i have done it plenty of times.
Measure how deep you want to go on an empty stud place ...do it while the wheel is in the air and all other lug nuts of once you feel you are depp enough use the wheel sideways...all this if it is a rear wheel ,with hand brake on...if front also lift but not much so your wheel does not spin..in the end,you can even use a tiny chisel but be careful Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 01-12-2020 at 02:25 PM.. |
Search the forum, this comes up all the time. You need to be careful and do the right thing or you risk you wheels.
1988 Carrera coupe 1966 250 Ducati 2015 VW Golf TDI gone because Dieselgate! 2021 VW Golf TSI 2014 Ninja 300 |
dont drill it! they make tools for that
https://www.tooldiscounter.com/product/ken-tool-lock-removal-kit-hubcap-and-wheel-ken30170?gclid=CjwKCAiApOvwBRBUEiwAcZGdGP6px9zKWEn uiCxx3m6DnhK0BSmmTd8ZNIBP4xwWYGCdqO1fgGpWdhoC7NwQA vD_BwE they may even be available for rent from the auto parts store
82 SC , 72 914 |
these work too if you find a big enough set
https://www.lowes.com/pd/CRAFTSMAN-6-Pack-Standard-SAE-Impact-Bolt-Extractor-Set/1000594521?cm_mmc=shp-_-c-_-prd-_-tol-_-google-_-lia-_-215-_-powertoolaccessories-_-1000594521-_-0&store_code=202&placeholder=null&gclid=CjwKCAiApOvwBRBUEiwAcZGdGP8zCgjSjQpJMqASAfAk LlSMESFf1hS6ox0OSISIOTVF2eHFhip4uBoCuaYQAvD_BwE&gclsrc=aw.ds
82 SC , 72 914 |
nothing to see here
Is that a steel mcgard locking wheel nut?
Sacrifice a socket. Had to do it on my daughter’s Mini Cooper. Use a socket that is a little too small. Hammer it on and take off with a breaker bar. Doubted my neighbor but it worked.
I see the space is tight hopefully enough room. |
They sell wheel lock removing sockets at autozone. Or as said just hammer a socket on it,
89 930 Cab Black 11 Cayenne |
