andrew15's Avatar
Crane Optical Triggering of Bosch CDI
I just bought the Crane Optical Pickup Trigger and installation kit from Pelican and was wondering if anyone has a diagram detailing how to wire this up.
The instructions detail the install of complete Crane systems and such, but I'm looking to use the optical trigger to trigger the Bosch CDI and use the stock coil as per the Pelican catalog.
I checked the archives but most installs seem to be the xr700 system.
Anyone out there that can help?
Regards,
Andrew M
1970 911T
1970 911E - track / weekend car
1970 911S - under restoration
1986 930 Slant Nose - fun car
Current used parts for sale
Old 04-02-2003, 08:22 PM
I'm looking for similar guidance: Crane optical trigger to MSD in my '76 Carrera 3.
Al G
Old 04-03-2003, 02:48 AM
Cool
TimT may have the answer.. he's been using the optical for a long time..............Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-03-2003, 04:58 AM
arrivederci's Avatar
I did this roughly two years ago on my '72 T. You don't want to connect it directly to the coil. You need to find the wire that triggers the CDI to fire the coil. It took some probing with a meter to find the correct wire.
FWIW, my car didn't run properly when I had the xr700 connected directly to the coil (bypassing the CDI).
- '72 911T
- '81 911SC Euro
Old 04-03-2003, 06:25 AM
Early_S_Man's Avatar
Porsche Crest
Josh,
The OEM Bosch coil for CDI-systems only has a 1:100 turns ratio ... and was NEVER designed to have 12 Volts fed to its primary winding!!!
Bypassing the CDI-system in a 911 requires a conventional [i.e., Bosch 'Blue' ] ignition coil be substituted ...
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 04-10-2003, 08:27 AM
This link should help.
Help with Crane optical trigger connection.
Rod
Old 04-10-2003, 09:22 AM
Navin Johnson
TimT's Avatar
Ron I sold my old ignition system to another fellow last year, went to crankfire.
I set up my optical trigger about 15 years ago when it was called an Alison xr700. from what I remember it was a pretty staightforward install.
'69 911 GT-5
'75 914 GT-3
and others
Old 04-10-2003, 01:41 PM
