Deleted due to too much junk answers
Old 01-05-2020, 03:28 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
Would the power loss be measured in 10ths of a horsepower? I can't imagine that gear oil, other than maybe if cement was used in the box, would create much measurable resistance.
Old 01-05-2020, 04:10 PM
Old 01-05-2020, 04:27 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
The difference is Racing is one thing; driving is another. Racers will always trade logivity beyond the next race for a 1/10th here and there. Question is, how often do you want to overhaul your trans?
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 01-05-2020, 04:34 PM
Old 01-05-2020, 04:36 PM
Old 01-05-2020, 04:38 PM
Frustrating isn’t it when racing teams won’t reveal the results of thousands of dollars in research so their competition can be on par.
Suggest SAE:
Focus on drivetrail loss. Membership is reasonable and access to the pubs is awesome.
https://www.sae.org/publications
I can recommend the History and Development of the Pratt and Whitney R-2800 book, shows the testing to destruction of an aircraft motor design.
Old 01-05-2020, 04:43 PM
Originally Posted by Litle brother View Post
I am sure you could measure the centistokes of both fluids, and do the calculations, it is after all, just physics. My neighbor has a PhD in physics and specializes in fluid dynamics, I asked him the same question he said “give a grant for 2 mil, and a year and I can give you a pretty good approximation” He works at NASA as a theoretical physicist, on rocket motors. I would question anybody who says they have an exact number. PM Matt Monson, he will be the closest answer you will get here.
Old 01-05-2020, 04:53 PM
Windage is a huge concern, from NASCAR to F1.
Old 01-05-2020, 04:54 PM
dreichman's Avatar
As the head line indicates I wonder if anybody has experience reagarding 915 drive train loss measured on the dyno using regular/factory gear oil VS the thick Swepco 201?
I have read on the "Great www" that thinner gear oil has been used in race cars during qualification to make better times than oil used during races.
I have also read that running with 10-20mm lower oil level in the 915 also contributes to less drive train loss.
So can one, in light of the above(among many other factors) assume that running the Swepco 201 results in a bit more more drive train loss?
Cheers
Eskild
I think it would be a distinction without a difference. Maybe measurable in mathematical terms but Not by the seat of the pants method, LOL
Old 01-05-2020, 05:54 PM
LJ851's Avatar
I think Rawknees got banned for too much windage a little while back.
Old 01-05-2020, 05:56 PM
Ha ha - ain't dat' da' truth! Maybe I shouldn't use Swepco when posting!
Old 01-05-2020, 06:00 PM
Old 01-05-2020, 06:06 PM
Like a fart in an elevator....
Old 01-05-2020, 06:19 PM
Still here
pmax's Avatar
Actually, factory recommends 90 which is thicker than 201.
Old 01-05-2020, 06:21 PM
Stranger on the Internet
patkeefe's Avatar
I think the variants in ingredients of gear oils have to do with the variety of dissimilar metals found in a gearbox, ie, hardened steel gears, brass synchronizers. Evidently SWEPCO was formulated by request of a Porsche race team.
That said, I did have to learn about this stuff once in engineering school, but thankfully, I've mostly forgotten it. I'm sure it is quantifiable. I do think it is a mistake to equate "thicker" to "more resistance", especially at room temperatures.
The old timers told me that during the second war, farmers used to put sawdust in the gearboxes and differential to quiet them down. Good gear oil must have been hard to obtain back then.
Also, you could also consult API and ASTM.
Patrick E. Keefe
78 SC
Old 01-05-2020, 06:42 PM
I tried to hold it in, I swear, but that black bean and egg burrito would not be denied!
Old 01-05-2020, 11:15 PM
Racer
winders's Avatar
If you are racing, use Swepco 210......actually, I would use it my street car too if I had one with a 915.
Only racers with big budgets and in-house mechanics would risk running oil that it too thin just to gain some HP. In other words, the typical club racer would not use thinner oil just to gain a few HP.
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 01-06-2020, 12:05 AM
Go on a diet and loose 10 pounds. No cost to do, and it will make your car faster in every aspect than thin transmission oil. But hey, it is your transmission, not mine. When the engine and transmission are at full operating temp, that oil is not that thick.
Old 01-06-2020, 06:37 AM
Geary's Avatar
Thinner gearbox / diff oils are for drag racers. They run their gearboxes cold, and only a few miles per year.
Old 01-06-2020, 07:26 AM
