wareaglescott's Avatar
Sunroof seal adhesive and weatherstrip adhesive
Got my SC back from paint. Have pretty much all new sunroof seals, as well as doors, hood seals etc. Never done anything like this.
Is there a recommended adhesive for installing these items?
The sun roof has a velvet seal that goes on the body, one that goes on the sunroof panel, and a rubber seal that also goes on the sunroof panel. Do the velvet and rubber seals require/ recommend a different kind of seal?
Thanks in advance!
Old 01-06-2020, 08:02 AM
Slippery Slope Expert
Steam Driver's Avatar
3M weather strip adhesive works fine. It’s available about everyplace. It comes in both yellow and black; I recommend the black since that matches the strips. Also get a can of 3M weatherstrip adhesive cleaner for removing excess - there will be that. It won’t damage your paint.
“As new technologies become indistinguishable from magic, and I can no longer tinker, the magic goes away for me.”
Old 01-06-2020, 08:12 AM
I second the use of 3M adhesives....clean surfaces and a "no-rush" approach will make the task less stressful.
Old 01-06-2020, 08:37 AM
Thank you! Will get some 3m adhesive
Old 01-06-2020, 10:14 AM
Yes, I have tried all different types and the 3M weatherstrip adhesive works the best.
I didn't know that it came in black, I only have the yellow. But would agree that black is better than yellow, because the yellow ages to orange and looks like rust over time, plus that stuff makes a huge mess and ends up seeping out of your weather strip. The adhesive remover is also very good idea, as well as a box of rubber gloves so you can keep your hands clean.
1970 911 T
2004 Carrera 4S
Old 01-06-2020, 11:31 AM
freesaints's Avatar
Another vote for 3M weatherstrip adhesive
1987 Porsche 930 - Grand Prix white
1998 Acura NSX - Kaiser silver
1976 Jeep CJ5 - Sunshine yellow
Old 01-07-2020, 06:23 AM
Discseven's Avatar
Eagle... suggest speaking with someone who will explain how to stretch & cut the rubber inside the sunroof seals to make the tuck between the sun roof panel seal and roof seal tight and look right on both sides.
Another thought... clean out drains while dealing with sunroof.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 01-07-2020, 05:38 PM
sithot's Avatar
3M 1357 has been used on aircraft door seals. A friend in that business told me about it and I've used it on 911 door seals successfully. It is a brush on product that tacks fast. The trick is to do small sections at a time because it does tack/cure so quickly. It holds seals very well. No more waiting for the cure or watching a seal fall out of the channel during the cure. Once it sets, you're done.
A product I was recently shown by a restorer is Kent Automotive P10190 Ultra Stick. It allows more working time but still has a terrific hold once cured.
Were I doing a sunroof seal I might consider this a better option because it is clear.
R Gruppe #111
Early S Registry #235
res ipsa loquitur
Old 01-07-2020, 07:25 PM
calidude's Avatar
There is a good post on this for the DIY, used 3M on mine too
1987 Porsche 911 Carrera - Lagoon Green
Old 01-11-2020, 03:51 PM
sithot's Avatar
Photos of the two products.
R Gruppe #111
res ipsa loquitur
Old 01-12-2020, 05:42 AM
where is this post at?
Old 01-12-2020, 07:40 AM
calidude's Avatar
Sunroof cable repair and new seals 87 911
See post 136 as did this and there is a photo of the correct adhesive
Old 01-12-2020, 09:22 AM
