Super Moderator
cstreit's Avatar
TWO voltage regulators?
Well I installed the new Motorola/Marshall regulator and still got 18 volts out of my system... So I took off the oalternator and lo and behold it's a Paris Rhone with an INTERNAL regulator...
So are their TWO VR's on an early car? Or is the external one redundant (mind you I have an 83 motor in a 70 car) with the INTERNAL one failed?
Wish I had looked at the alternator before I ordered the new external regulator
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 04-04-2003, 10:37 AM
Cool Re: TWO voltage regulators?
you probably gotta do a good rebuild, and make a gift to the local 911 shop.............Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-04-2003, 02:19 PM
pwd72s's Avatar
Isn't 18V too high?
Old 04-04-2003, 04:40 PM
Bill Verburg's Avatar
Somebody neglected to finish the job when the new engine was transplanted in. One of the 2 v/r was left but not not hooked up. Sounds like the internal one is defective and the other is just taking up space.
Bill Verburg
Old 04-04-2003, 05:33 PM
Somewhere in the Midwest
MotoSook's Avatar
Bill, BULLS EYE! I spoke with Chris earlier (he's away from the computer).
Same thing with my motor, external reg, not used, but taking up space!
Old 04-04-2003, 06:11 PM
external regs should be removed, not just disconnected, when an internally regulated alternator is installed, to keep someone from saying, "hey, this plug isn't connected", and plugging it back in.
206 637 4071
Old 04-04-2003, 07:14 PM
MotoSook's Avatar
John, what whould happen if the two were plugged in?
Old 04-04-2003, 07:23 PM
Super Moderator
cstreit's Avatar
Well the second external one WAS "vestigial" as one of the two wires coming off of it was clipped (per a factory recommended upgrade some time ago).
Bill was dead on. All they had to do was remove the damn thing and it would have saved me a LOT of hassles...
Anyway, new alternator installed and the system runs at a steady 14.1 volts at all RPM's!
This same issue probably was the cause of my electromotive failures as well, so a ampmeter and voltmeter are going in tomorrow.
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 04-04-2003, 08:21 PM
Cool
you don't need an amp meter.. an analog/not digital volt meter and CHT are on my console.. you can even have both made in one ga. package...........Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-04-2003, 10:14 PM
Super Moderator
cstreit's Avatar
CHT?
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 04-05-2003, 06:05 AM
cylinder head temp.
72 911t grey/black mine
74 914 2.0 black/ tan hers
02 g500 black/black womanproof
01 f250 psd dirty the mule
60 correct craft starflite cool
69 correct craft torino hauls butt
72 correct craft ski nautique fun
66 vw 1500s will finish someday
Old 04-05-2003, 06:24 AM
CHT, it comes from the aviation world, another would be EGT "Exhaust Gas Temp"
Keith
Keith
Drive Hard and Fast
1991 Carrera 2 Targa
1972 911T Coupe
1971 914
Old 04-05-2003, 08:31 AM
Are you talking about a volt/CHT combo to replace the clock? This is one of my future projects, but I'll buy one premade if they exist (no use reinventing the wheel). I posted a thread earlier about this, but no one every replied as to seeing one.
Chris M
1985 911 Carrera w/ 3.6
Old 04-05-2003, 11:30 AM
Cool
[QUOTE]Originally posted by jazzbass
"Are you talking about a volt/CHT combo to replace the clock?"
--- you can do that.. I have mine on lower console/below dash because it doesn't need constant attention.. and an analog because a quick eyeball scan of the needle is all I need..
" This is one of my future projects, but I'll buy one premade if they exist (no use reinventing the wheel)."
--- yep, they do search around to get what you want.. I use Aircraft Spruce
"I posted a thread earlier about this, but no one every replied as to seeing one."
--- you can get any gauge size/combo that you want
.................Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-05-2003, 11:52 AM
McDaniel's Avatar
Ahem...Raising Hand
Excuse me, if any of those regulators you don't need are the
external type that will fit my '74 with the Marchal alternator...
I'd like to buy...
This is not the plug in type that was standard on the '75+
Impotence...Nature's way of saying "No hard feelings."
McDaniel
1974 911 Targa
1995 Toyota Avalon
2004 Toyota Tundra Extended Cab
Old 04-05-2003, 12:53 PM
