Free minder
Aurel's Avatar
Ignition troubleshooting
On my 78SC, ignition stopped working all of a sudden.
I took the cap off and noticed the rotor tip was broken, which explains the loss of ignition. It looks like rotor got slightly dislodged and hit the distributor inside, for some reason. I replaced the rotor and distributor, but still got no spark.
Now, I suspect that my coil burnt out because of the rotor failure. Having no rotor working would be like cranking the engine with the coil disconnected, which is known to burn them. Are my assumptions correct, has anyone else experienced something similar?
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 01-26-2020, 07:31 AM
Free minder
Aurel's Avatar
I tested the resistances in the coil, 0.9 ohms for the primary and 5k ohms for the secondary, so that looks ok. It would have been an easy fix...
Old 01-27-2020, 04:29 AM
Do you have the Bentley manual? Check for a pulse from the distributor as described on page 280-9
1959 Bristol 406 (bought in 1972; sold in 1977)
1966 Porsche 2.0 coupe (bought in 1977; sold 1981)
1978 Porsche SC coupe (bought in 1993)
Old 01-27-2020, 07:30 AM
Under the radar
Trackrash's Avatar
This thread kinda covered it. The Green wire...
Gordon
'71 911 Coupe 3,0L outlawed
Old 01-27-2020, 05:22 PM
Free minder
Aurel's Avatar
Yeah, it could be the green wire again, but I replaced her a while ago...although that was like 15 years ago, how time flies...Thanks for the reminder on the green wire.
Old 01-28-2020, 04:03 PM
ROW '78 911 Targa
timmy2's Avatar
Type of CDI?
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 01-28-2020, 04:42 PM
Free minder
Aurel's Avatar
Originally Posted by timmy2 View Post
Type of CDI?
MSD streetfire with MSD coil blaster. Been working great for 5 years.
Old 01-28-2020, 04:51 PM
Free minder
Aurel's Avatar
I found a neat test to check the MSD and the coil:
Quick tip for MSD Streetfire users
Old 01-28-2020, 04:59 PM
ROW '78 911 Targa
timmy2's Avatar
Is it possible the MSD is cooking the resistor in the rotors?
Check the resistance from rotor tip to center to make sure.
Dennis
Old 01-28-2020, 07:02 PM
It appears that the rotor tip has been over heated and may have failed similarly as the resistor due when using MSDs. I would also check the distributor play to rule out a mechanical failure from worn bearings.
Old 01-28-2020, 10:24 PM
The MSD WILL cook the resistor. Either use a VW rotor witn no resistor, or carefully remove the resistor with a dremel and solder in a solid copper wire and then pot it.
I have a Daytona-Sensors CDI and this is what I had to do. My rotor has been "rotoring" for 10 years with no problems.
I use the built in soft rev limitor instead of the centrifugal weight rotor rev limiter.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 01-29-2020, 02:05 AM
Free minder
Aurel's Avatar
If only the resistor in the rotor got cooked, then the new rotor should have fixed the issue, at least temporarily. Something else is preventing the spark now. But I have good leads to investigate, thanks to this thread.
Old 01-29-2020, 02:53 AM
Free minder
Aurel's Avatar
Update: I tested the spark at the coil and got an orange spark. Can a coil be weak? I also switched to resistor-less distributor, that did not help.
Next move: I could spend $45 on a new coil...
Old 02-23-2020, 08:42 AM
Free minder
Aurel's Avatar
Final update: I put in a new coil, the spark was brighter, and the car started right away. In hindsight, the failure was the rotor resistor, so I went resistor less. And somehow the coil got weak too, but now all is fixed.
Old 02-29-2020, 11:32 AM
