T77911S's Avatar
connector for knock sensor
where would I get a connector for this knock sensor
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 01-27-2020, 06:37 AM
Amazon, just type in knock sensor pigtail
Old 01-27-2020, 08:24 AM
Stranger on the Internet
patkeefe's Avatar
www.eagleday.com
There are other places online, but I forget them off the top of my head. I think that is a sort of AMP connector.
Patrick E. Keefe
78 SC
Old 01-27-2020, 09:52 AM
It is the same connector as used for EV-1 fuel injectors.
-Dennis
1977 930 Slant, MS3 EFI, Carrera intake, Twin plug, Powerhaus headers, Magnaflow muffler, Garretson intercooler, GTX3071R
Old 01-27-2020, 09:53 AM
It's an Tyco/AMP (Amphenol) Junior Timer connector.
'77 S with '78 930 power and a few other things.
Old 01-27-2020, 02:09 PM
rsscotty's Avatar
This does not take a Tyco/Amp connector.
It uses a Bosch Compact 1
You can get the kit from Finjector, part number (1 928 403 137 ) The kit labeled SET-1 will work with 17-20 ga. wire
Not easy to find parts in kit form.
Old 01-27-2020, 05:46 PM
Huh, never noticed that before...
Bosch knock sensors are available with 2 types of connectors (and also the "modern" connector can be had either terminating on the sensor body, or with an attached lead - KS-4-S vs KS-4-K1 respectively).
Bosch says knock sensor connectors are either:
2-Pin RB-Kp.1 (F 02U B00 966-01)
Or
2-Pin Jetronic (D 261 205 288-01)
The Jetronic is the same connector as a Bosch NTC thermo-sensor (same family as the 3 pin variant often used for the mag crank/ref sensors), often called a JT connector. Same as many connectors on a CIS loom - eg WUR, AAR. That's the only type I'd seen.
The JT can be crimped satisfactorily with a $15 ratchet crimper with suitable dies for open-barrel terminals and the gauge of wire used. Dunno about the other one.
Old 01-28-2020, 02:42 AM
T77911S's Avatar
this one takes the EV1?
does it matter which one I use.
would like to use one that I can easily find a connector for but also works well.
RACE CAR:: sold
Old 01-28-2020, 03:53 AM
Diss Member
Quicksilver's Avatar
A Junior Timer connector is much more rectangular than that.
(It is surprising how many places the Junior Timer connectors are used. First place I saw them was the crank sensors on the Carrera but now I see them all over. They even use them on my cheap 90's Nissan pickup!)
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 01-28-2020, 11:05 AM
Racer
winders's Avatar
https://www.bmotorsports.com/shop/product_info.php/products_id/942
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 01-28-2020, 11:48 AM
T77911S's Avatar
does it really matter which sensor I get.
been trying to get info on them but not really any out there.
I assume the 2 wire ones are better than single wire for noise
RACE CAR:: sold
Old 01-29-2020, 03:58 AM
Bosch publish several datasheets, including drawings, fitting specifications and vibration/thermal/corrosion/lifetime specs.
Google "bosch Y.261.K23.205" for the Jetronic connector and "bosch KS4-P datasheet" for the other one.
Apart from the connector, they're the same sensor.
They're all 2 wire, it's a piezo microphone. Doesn't matter which wire goes where, but you need both. The only difference is the connector; which is better for you probably depends on which crimping options you already have.
Old 01-30-2020, 05:11 AM
kevingross's Avatar
https://www.bosch-connectors.com/
Kevin
Catellus Engineering
catelluseng@gmail.com
http://www.catellusengineering.com
https://www.facebook.com/catelluseng/
Old 02-02-2020, 06:17 PM
T77911S's Avatar
I ordered 2 of these.
came with connectors so no worries.
https://www.bmotorsports.com/shop/product_info.php/cPath/129_589/products_id/4514
also ordered this air temp sensor.
I ordered a M18 to M14 adapter so I can mount it in the IC right above the throttle body.
hope the engine shroud does not get in the way.
https://www.bmotorsports.com/shop/product_info.php/cPath/129_142/products_id/4174
RACE CAR:: sold
Old 02-03-2020, 03:51 AM
