Diving in 911
964 motor low point?
Will a 964 motor sit flat on its stock exchangers, or is the case split line lower? It looks lower is why I ask. If so, safe to set it on a cart with one heat exchangers acting as an outrigger?
Thanks!
1976 911s Special Edition Turbo bodied IROC tribute
2002 911 Carrera C4S
1971 914 1.7 Tangerine
1989 964 Coupe/1992 964 Cab
1987 928s4 Granite Green / 1986 951
Old 02-22-2020, 06:45 PM
I have put mine on a cart sitting on the heat exchangers. No problem.
Old 02-22-2020, 06:53 PM
Diving in 911
Does it sit flat, or slightly to one exchanger?
Old 02-22-2020, 07:05 PM
IIRC it sat flat.
Old 02-22-2020, 07:16 PM
Personally, I always 2x4s or something to support the weight of the motor and use the heat exchangers for balance.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 02-23-2020, 09:31 AM
Diving in 911
With the stock exchangers, it looks like the flywheel end of the motor would rest on the exchangers, but the case would be the lower parts as you move to the fan end, correct? So it’s sort of a triangle that it sits on. You block up the center line then shim the exchangers?
Thanks!
Old 02-23-2020, 09:44 AM
Mines (the pic) a 3.3 So, probably a bit different. I should have read the posts more carefully.
It sounds like the 964 hits the case first. Should be fine.
Old 02-23-2020, 12:07 PM
