'73 911 T Targa
How does the trans linkage boot work ?
The inspection plate for the trans linkage on my car was removed during the re-carpet process. I noticed that the boot is not properly in place. It doesn’t seem to fit inside or outside the bushing where it passes through.
How is this supposed to work?
Old 02-06-2020, 08:38 AM
'73 911 T Targa
Here’s a picture of the scene of the crime.
Old 02-06-2020, 08:41 AM
Under the radar
Trackrash's Avatar
It fits on the outside of that flange at the rear of the tunnel. It is a beeach to get on.
Gordon
'71 911 Coupe 3,0L outlawed
Old 02-06-2020, 10:29 AM
stevie 77 930's Avatar
trans linkage boot
Roll the outer edge about 1/2 an inch inside out. Start from the bottom and roll it onto the lip working your way up.
1983 911SC
1977 930 Turbo (again)
2018 GTS
2023 Audi A4
'74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone)
Old 02-06-2020, 12:08 PM
Perpetual Reassembler
2jmotorsports's Avatar
Does the accordion boot fit over the outer boot that also fits on that tunnel flange and sticks out the back of the tunnel over the shift rod?
Jose - 1983 911SC Coupe
Instagram: @joe_engineer
911 D I Y Blog: joe-engineer d o t c o m
D I Y Vids: https://www.youtube.com/joeengineer
Old 02-06-2020, 01:05 PM
trans linkage boot
Yes, the "accordion" boot fits over the the outer boot.
1983 911SC
2018 GTS
2023 Audi A4
Old 02-07-2020, 09:08 AM
Jtt84911's Avatar
What many do (including me) is after you get the back section in place...wrap a cable tie around it. Once that’s nice and tight... if will not pull off again.
Regards,
JT
Old 02-07-2020, 10:45 AM
