911 vs. 951 9" Fuchs
I have read a bunch of threads and I'm still confused.
I have a set of 9" X16" Fuchs.
One wheel has part number 951.362.11(8).
One wheel has part number 911.362.119
Both wheels are ET15
Both wheels have AS1062
Both wheels are date stamped 1987. One in week 14 and one in week 18.
What car would the 951 part number be from?
The wheels look absolutely identical.
Thanks. Don
(Yes, they will be for sale with a set of 7" fronts, date code from 82, as soon as I figure this out.)
Old 02-08-2020, 12:53 PM
SWS911's Avatar
Which date code is which? Part numbers may have been superseded.
I don't think the 9X16 ever came on any 944, but did come on the
'86 to '89 911 Turbo. They look like the 944 wheel (951) with the lug
bolts "countersunk", but that's a good question on the part numbers.
Old 02-08-2020, 01:08 PM
Bill Verburg's Avatar
Thanks. Don
911.362.119 is a valid part 3 for a 9x16 Et15 wheel, oe was late 930
951.362.11(8). is not a valid Porsche part #
here are some valid ones
8*16 ET23,3 944 offset 951 362 117 00 Black/-86
8*16 ET23,3 944 offset 951 362 117 90 Unpainted/-86
7*16 ET23,3 more caliper room 951 362 115 90 Unpainted/-86
7*16 ET23,3 more caliper room 951 362 115 00 Black/-86
Bill Verburg
Old 02-08-2020, 01:22 PM
proporsche's Avatar
Bill, i do have rears 9th ....951 are the front 8th...offset
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 02-08-2020, 01:58 PM
proporsche's Avatar
i found this i have saved...
Standard Fuchs (Fuchsfelgen) Size Offset Backsize Part Number
1984 - 6.0 x 16 36.0 mm 121 mm 911.362.113.00
Std 6J x 15 : 185/70 front, 7J x 15 : 215/60 rear 6.0 x 16 36.0 mm 121 mm 911.361.020.43
Std 6J x 16 : 205/55 front, 7J x 16 : 225/50 rear 7.0 x 16 23.0 mm 122 mm 911.362.115.00
Opt 7J x 16 : 205/55 front, 8J x 16 : 225/50 rear 7.0 x 16 23.0 mm 122 mm 911.361.020.44
1987 - 7.0 x 16 23.0 mm 112 mm 951.362.115.(944)
Std 6J x 15 : 195/65 front, 7J x 15 : 215/60 rear 8.0 x 16 10.6 mm 112 mm 911.362.117.00
Std 6J x 16 : 205/55 front, 7J x 16 : 225/50 rear 8.0 x 16 10.6 mm 112 mm 911.361.020.45
Opt 7J x 16 : 205/55 front, 8J x 16 : 225/50 rear 8.0 x 16 23.3 mm 135 mm 951.362.117.(944)
1988 - 9.0 x 16 15.0 mm 130 mm 911.362.119.00
Opt 7J x 16 : 205/55 front, 8J x 16 : 225/50 rear Size Typre options Off set
1989 - 6 x 16 205/55 6 J x 16 H2 - 36,0 mm
Std 6J x 16 : 205/55 front, 8J x 16 : 225/50 rear 7 x 16 205/55 : 225/50 7 J x 16 H2 - 23.3 mm
Opt 7J x 16 : 205/55 front, 8J x 16 : 225/50 rear 8 x 16 225/50 : 245/45 8 J x 16 H2 - 10.6 mm
Tyre pressures - Front 2.0 bar (29psi), Rear 2.5 bar (36psi). 9 x 16 225/50 : 245/45 9 J x 16 H2 - 15.0 mm
Turbo -
Opt 7J x 16 : 205/55 front, 9J x 16 : 245/45 rear Upgrade
Tyre pressures - Front 2.0 bar (29psi), Rear 3.0 bar (44psi). 7 x 16 205/55
8 x 16 225/50
9 x 16 245/45
Old 02-08-2020, 02:20 PM
Ivan
Bill Verburg
Old 02-08-2020, 02:53 PM
Turbo -
8 x 16 225/50
9 x 16 245/45
And this helps How?
Bill Verburg
Originally Posted by Bill Verburg View Post
And this helps How?
It gives you the dates and part numbers of the different sized Fuchs. As already stated, 9X16 Fuchs never came on a 951, in fact, when started offering the 9X16 Fuch, the 951 series had already switched to the late (53mm) offset.
Now the
Club Sport wheels available on the 944Turbo S and 928S4s were made by Fuchs. Picture below of 9X16 Club Sports by Fuchs.
Don't forget, 9X15 Fuchs were available in the 70s.
Old 02-08-2020, 04:59 PM
More irrelevant info, I confirmed the correct 9x16 Et15 Fuchs info which matchs 1 of the op's wheels, and identified the other part # as invalid and also provided the valid 951 wheel #s and descriptions, he obviously has a 9 and either 7 or 8 951 wheel . The 951 9 is ET60 part#928.362.119.30 or ET70 part #944.362.118.01 There was also a Telephone dial 9ET57 part # 951.362.118.10 and a design 90 9 ET52 part #928.362.118.02 but none of these are Fuchs 5 spoke wheels which was what the op asked about and so are irrelevant to the thread.
.... Now the
Don't forget, 9X15 Fuchs were available in the 70s.....
again the question was about Fuchs 9x16 ET15, the older 9x15 ET3 part # 911.331.012.05 is irrelevant and just muddies the water as far as answering the question
the only 951.***.***.** Fuchs were the 7 & 8's I posted, there are several other versions w/ different last 2 digits but they are just cosmetically different or from a different casting batch
Bill Verburg
Old 02-08-2020, 07:22 PM
Well muddied bill .
Old 02-09-2020, 06:56 AM
Thanks, everyone. I've attached some pictures. Bill.. If there is no such thing as a 9", 951 wheel then this is an amazing reproduction. I've also attached a picture of the 911 part number. Do these make things more confusing? Thanks again.
Old 02-09-2020, 07:57 AM
Mistakes happen during manufacturing, obviously this is another example of one. I've seen this many times.
The wheel speaks for itself, it is identical to the correctly labeled one, it just has an erroneous ID.
For a given wheel spec only the last 2 digits change w/ cosmetics or casting batch differences.
Both of your 9s are 911.362.119 oe on late 930s
Bill Verburg
Old 02-09-2020, 08:41 AM
Thank you Bill. I guess I'm not shocked that the quality control at Fuchs and Porsche were suspect in the late 90's before the Japanese arrived. On that note are miss marked wheels, like old coins, worth lots more? LOL
Old 02-09-2020, 08:53 AM
If you want to compare to the other Fuchs for 911 here are some specs
overall edge to edge width of a 9, 246mm(~9.7"), ET15 all are 911.***.***
overall edge to edge width of an 8, 219mm(~8.7"), ET10.6 for 911 parts and 23.3 for 951 parts
overall edge to edge width of a 7, 194mm(~7.7")ET23.3 there are 911 versions and 951 versions the 951 versions have extra caliper room
all 951 have counter sunk lugs
Bill Verburg
Old 02-09-2020, 09:31 AM
