Which replacement panel is this rust in (69 E)
Is this right front gas tank lateral support panel, or the front pedal area section and would I order the replacement panel with, or without, the brackets? 1969 E
Thanks,
Milan
Old 02-19-2020, 01:26 PM
You don't want replace that panel, trust me. Just fix the rusted area and be happy.
206 637 4071
Old 02-19-2020, 01:34 PM
The rust is right on the pinch weld/bead, how would you recommend repairing it so it's a good job?
Old 02-19-2020, 01:43 PM
Have a shop do it that's familiar with the breed. Dropping the entire front suspension probably required, but that's pretty quick and easy. Then you have access.
206 637 4071
Old 02-19-2020, 01:49 PM
I would rather be driving
jpnovak's Avatar
Agree. That is not a panel I would trust to anyone but a highly competent body shop.
The steering tunnel section is also called the front floor area. The factory has a single piece that goes from the front pan into the floor board to rear bulkhead. You can buy just the one section from our host.
https://www.pelicanparts.com/More_Info/PELP218B.htm?pn=PEL-P218B&SVSVSI=911E&DID=57399
John is correct that it is much easier to just drop the suspension and weld in a patch. YOu won't know how big if a patch until you cut it open.
Old 02-19-2020, 02:01 PM
I actually have that whole panel from Restoration Design, with just a small pedal area section cut out for my '69.
206 637 4071
Old 02-19-2020, 02:14 PM
