VFR750's Avatar
Engine Removal Checklist
Here is the checklist I use to remove the engine and transmission.
Will be starting the process today, to do a transmission swap.
This applies to an engine with carburetors. I do not need to remove the bumper, if i take the carbs off.
If you leave the fuel system attached, then the bumper has to come off, or you get the car higher off the ground.
Mike
'82 911SC, SSI, 22/29 tbars, 22F/22R Adj swaybars, Bilstein Sport, Elephant polybronze & monoballs, Cambermeister bar, turbo tierods, Carrera oil cooler, front brake cooling ducts, Sparco Sprint 5 & Recaro SRD PAX seat, Teamtech harness, DAS Sport rollbar.
Old 02-22-2020, 05:58 AM
cycling has-been
bkreigsr's Avatar
Nice list, thank you for sharing.
FWIW, as they say in the manuals: "Installation is the reverse of the above."
(What happens if you don't use the bungee on the clutch pedal?
That step is not in the factory book.)
Bill K
Old 02-22-2020, 06:47 AM
VFR750's Avatar
If you don’t bungee the clutch pedal, the helper springs snap it to the floor and the cable connection inside the tunnel may pop off. Which means you’ve added another task to the list.
Yes, reverse the process to install.
Old 02-22-2020, 07:07 AM
proporsche's Avatar
don`t worry too much about the clutch cable falling off it is held in place by clevis and secured.Just disconnect the cable at the clutch arm with Omega spring and let the cable slide-pedal to the floor board....
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 02-22-2020, 08:13 AM
Additional missing steps.......
Do not forget to disconnect the delivery and return fuel lines. And the electrical connections to the 14-pin connector and main engine harness. And others.
Tony
Old 02-22-2020, 09:45 AM
