lateapex911's Avatar
Displaced chain guide...
So, my 2.7 was built by a pretty reputable shop here in the NYC area, but when they first opened, years ago. Due to life BS, the car has gotten little use since then. Maybe 3K miles. It's never run right, backfiring through the carbs. I've replace the carbs with PMOs, the ignition system with a MSD and optical pickup, and it's always the same. Then a fuel line split while it was idling one winter in my drive and it caught fire. I was REALLY hard to put out and things got in the left side of the engine.
So I'm finally getting to it and pulling it apart.
When I pulled the left cam chain cover off, I found the chain ramp/guide lying in the bottom, ...It is normally mounted on two studs. It's got a bit of a dogeared look, but looks liike it would go back on once cleaned up.
huh?? Not what i was expecting.
The car does have oil fed tensioners.
I know there are lots of engine gurus here, any ideas how that happens? Why? And what to look for and do to make it right going forward?
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 02-21-2020, 05:27 PM
It takes pressure to get them to snap into place. I would guess that who ever was in there last didn't get seated and it just fell off.
Old 02-22-2020, 10:28 AM
proporsche's Avatar
picture will help of the situation..do not reuse the chain rail ..get new one, they are cheap...
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 02-22-2020, 10:31 AM
