964 wheels on 911 possible?
has anyone used spacers to fit 964 wheels (17x8 ET45 front 17x9.5 ET40 rear) on a narrow body 911?
Old 03-13-2020, 10:56 PM
9.5 rears are a tight squeeze (shave bolt heads, relocate oil lines, suspension/tire selection critical) in a G body. Gotta guess they won't fit a narrow (F) body.
'77 S with '78 930 power and a few other things.
Old 03-14-2020, 05:02 AM
Bill Verburg's Avatar
By n/b do you mean '69-77 or SC/Carrera?
If the latter then yes
8 on a 911 front wants an Et~27+/- for a comfortable fit w/ 225/45x17 tires, so a 964 8ET52 wheel would use a 25mm spacer(52 or 52,3 is the correct ET for 964 8)
9.5 on a 911SC/Carrera rear wants ET19, so for a 964ET68 use a 49mm spacer(68 is the correct ET for the oe 964 9.5)caveats use no bigger than a 255/40 x17 tire, if you do the trailing arm bolts will need to be trimmed , the oil line will need to be moved or flattened for any tire w/ the possible exception of a 245/40 x17
Bill Verburg
Old 03-14-2020, 09:51 AM
thanks bill. apprecaite the response. yes, the later - SC/Carrera.
based on your 964 numbers, I wonder if the wheels I mentioned are 964. that said, it seems they can work but will require the proper F/R spacer.
Old 03-14-2020, 01:30 PM
thank you. perhaps not worth it for another inch of rubber.
Old 03-14-2020, 01:33 PM
For those who are on the fence about the knowledge/Porsche information Mr. Verburg has, you only need to look at the things he posts. He recently assisted me in my "quest" to update the wheels on my SC. Regrettably, I ordered the wheels, last week, which is apparently about 4 weeks too late from Germany. God only knows when they'll be delivered. . . It's probably time to switch to Tecate beer and forget Corona.
Don Newton
“People sleep peaceably in their beds at night,” George Orwell wrote, “only because rough men stand ready to do violence on their behalf.”
"I gave up visiting my psychoanalyst because he was meddling too much in my private life." Tennessee Williams
Old 03-14-2020, 01:40 PM
Yes, if those are the true ETs, they are not 964 wheels, adjust the spacers accordingly
A friend got a screaming deal on these 993 16s for his SC, They are 7ET55 & 8ET70, for the SC he uses 31mm front and 59mm spacers rear, They look spectacular
Bill Verburg
Old 03-14-2020, 02:09 PM
