Hellraiser's Avatar
Send a message via MSN to Hellraiser
I had the same thing happen once when using the original orange compressor to inflate a tyre.
Old 03-13-2020, 02:53 AM
49willard
Jamell,
Thanks for posting your experience. I just removed the Dr. insert. Just looking at the insert it looks like trimming back the longer "tails", i.e. shortening the insert should avoid contact with the clips. It would seem that doing that and never using a metal barrel adapter could be the fix. Am I missing something?
Note that I like having the plug in digital voltmeter and occassional use of a GPS. With the exception of the recommended additional fuses my 911 is totally stock.
Bill
1961 356B coupe-long gone!
1986 Grand Prix White Cabriolet
Old 03-13-2020, 05:08 AM
Jameel's Avatar
Originally Posted by 49willard View Post
Jamell,
I think thats a good approach.
Old 03-13-2020, 05:26 AM
49willard
Thanks for your response. Sharing information as you have is where the forum provides real value. The short video was much appreciated. You have helped me. A gold star for Jameel!
Bill
Old 03-13-2020, 05:35 AM
'73 911 T Targa
For what it’s worth, these fuse holders are really nice for adding a in-line fuse. The connectors crimp like regular electrical connectors and the holder seals out dirt and water.
https://www.westmarine.com/buy/blue-sea-systems--in-line-waterproof-fuse-holder--11975885?recordNum=21
Old 03-13-2020, 08:44 AM
Banned but not out, yet..
RSBob's Avatar
Just doesn’t make sense to use the Dr B solution when there are now plenty commercially available products which do not have inherent risk. Flame on Levon.
Old 03-13-2020, 12:31 PM
Competizione's Avatar
I guess I just don't understand the need to 'jimmy' a cheap product so that you can charge your phone while driving your 911. Lesson learned....
Old 03-14-2020, 02:14 PM
49willard
I trimmed back the insert.Very easy to do and I have about 5mm gap to the contact. Thanks again to Jameel for the heads up.
Bill
Old 03-14-2020, 04:17 PM
Trimming back the insert sounds like a good solution. I'm also wondering if an application of Plasti-Dip or Liquid Tape as an insulator would be durable enough to do the trick when applied to the surfaces/edges that are the problem.
Marv Evans
'69 911E
Old 03-15-2020, 09:22 AM
Vintage Owner
Jack Stands's Avatar
Lighter insert
These use to be supplied with Escort radar detectors. Don’t know if anyone still makes them available.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 03-15-2020, 01:26 PM
Thread Killer
Teutonics's Avatar
That looks like it would be pretty simple to 3D model and print.
Allen
'85 911 Coupe
'75 BMW 2002
'02 Ducati Monster 900ie
'18 GMC Sierra Denali 6.2L 4wd
Old 03-16-2020, 06:13 AM
Jameel's Avatar
So the 911 has been back in action for a few weeks now. Thanks to the excellent service from Dennis Powell I had my rebuilt harness section ready to splice back in less than a week!
Here's what I did. I traced the harness back to good clean wire, just past the wiper motor section. Sent the toasted one to Dennis, and he built a new one using my original fittings and some of his new molded 6-pins. I then spliced it in using butt splices and heat shrink tubing, staggering the joints for a compact package. Dennis was invaluable through the whole process! The harness looks totally stock at this point.
I did not replace the cigarette lighter, because it's a joke. Everyone should replace theirs in my opinion with a USB charger, or just disconnect the wiring from your's if you want the look to be correct. I installed one I found on Amazon, with bonus volt meter. Here's the cool part. It can be installed from inside the car! Pull the radio out and you can reach up between the chassis panels to access. I did have to open up the hole a little with a step drill for the charger to fit. Just a millimeter or so.
While I was in there I also added some inline fuses to the deck lid light (out back) terminal 58a on the light switch, ash tray light, and most importantly I had Dennis add an inline fuse to the cigarette lighter wire so it's protected. It's long enough that I tucked it over near the right fender for easy access.
1983 SC Coupe Chiffon White
3.0 rebuilt by me
9.5:1 964 Cams. SSI's. Backdated heat. KEP sports clutch.
Old 04-28-2020, 06:51 AM
Wildman Emeritus
Is this USB mod made by Lucas?
Looks like a solid fix from an uncomfortable working position.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 04-29-2020, 07:41 AM
Jameel's Avatar
This is the one https://www.amazon.com/gp/product/B07PLQMTB5/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
3.0 rebuilt by me
Old 05-08-2020, 08:32 AM
