Jameel's Avatar
Warning: If you're using the Dr. Buzinski Cig Lighter Mod....
Put a new USB charger in my socket today, turned on the car, and it just about caught fire. I had the usb charger rotated incorrectly so the side terminals were buried in the spacer sleeve, shorting out. I currently have the fresh air blower out and am assessing the damage. Will report back soon....
1983 SC Coupe Chiffon White
3.0 rebuilt by me
9.5:1 964 Cams. SSI's. Backdated heat. KEP sports clutch.
Old 03-11-2020, 02:58 PM
ROW '78 911 Targa
timmy2's Avatar
Damn Jameel, that sucks.
Lighter wire runs in harness to 6 pin female through body blower motor plug then through entire harness back to fuse 16. Likely the longest wire in the dash harness. Hopefully it didn’t melt a bunch of insulation on the other harness wires.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 03-11-2020, 03:24 PM
Jameel's Avatar
I just pulled the car into the garage to further assess. I may need to call you!
3.0 rebuilt by me
Old 03-11-2020, 03:32 PM
HarryD's Avatar
For the uninitiated, what is this mod?
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 03-11-2020, 05:33 PM
Still here
pmax's Avatar
Ouch !
Tell us you took that pic after shutting things down.
Old 03-11-2020, 05:52 PM
Jameel's Avatar
Originally Posted by pmax View Post
Ouch !
Yes of course....but still panicking!!!
Old 03-11-2020, 05:54 PM
Jameel's Avatar
http://forums.pelicanparts.com/porsche-911-technical-forum/612310-dr-bulczynski-3-2-cigarette-lighter-mod-5-99-a.html
Old 03-11-2020, 05:55 PM
Jameel's Avatar
Ouch !
For entertainment value:
https://youtu.be/rs_E6gZG1-s
Old 03-11-2020, 05:57 PM
HarryD's Avatar
Thanks!
Harry
2020 MB E350 4Matic
Old 03-11-2020, 07:40 PM
MotorWorks's Avatar
Damn and I was about to do that mod. Might have to rely on my USB battery power brick stuck between my seats a little longer.
Matty
1979 911 SC RoW Slicktop
Old 03-12-2020, 09:16 AM
MBAtarga's Avatar
Jameel - can you post your issue on that other thread below? Better to bring this to light on that thread as well...
Dr. Bulczynski 3.2 Cigarette Lighter MOD $5.99
Mark
'83 SC Targa - since 5/5/2001
Old 03-12-2020, 10:18 AM
Ctopher's Avatar
I don’t understand the reason for this mod when a simple short USB charger like this works perfectly. I’ve had this in my car for 3yrs and had it once come out. The other times I had to use a USB cable to pull it out. No issue with the cig port, unless the 87+ cars got a different cigarette lighter.
AUKEY Car Charger, Mini USB Cell Phone Car Aapter 24W/4.8A Flush Fit Dual Port
https://www.amazon.com/gp/product/B00M6QODH2/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
CTopher
Old 03-12-2020, 10:24 AM
Jameel -- did you shorten the sleeve per the instructions contained in post #6 of the above thread before installing?
Old 03-12-2020, 11:22 AM
Jameel's Avatar
Not enough evidently! I'm not sure what changed this time around because I was running this exact setup for the last 3 years without issue. Just got unlucky I guess.
3.0 rebuilt by me
Old 03-12-2020, 06:44 PM
Jameel's Avatar
Here's a video I did explaining how I think my short happened. Feel free to post corrections or ideas. This is just a theory....
3.0 rebuilt by me
Old 03-12-2020, 07:09 PM
Banned but not out, yet..
RSBob's Avatar
Sorry to hear about you letting the smoke out Jameel. You will spend many hours redoing wiring, but you will get it.
A previous owner of my late 72 T wired an alarm to the clock power. Half a wiring harness later Ralf Meany had everything working again. His office was loaded with 914 trophies and racing memorabilia
Hopefully yours will not be as dramatic.
Old 03-12-2020, 07:11 PM
Jameel's Avatar
Thanks much Bob. I've worked on 90% of this car at this point, so I'm not afraid of tackling anything, but the hassle of tearing out the harness has me a bit ticked off, especially this time of year. Just itching to drive after four months of it being parked. Grr!! Someone should start a thread on what circuits are un-fused so we can all make our cars safe. Funny to mention the clock and a 72T! I know a local guy who had melted clock wires in his 72T!
3.0 rebuilt by me
Old 03-12-2020, 07:16 PM
RSBob's Avatar
While you are at it, fuse your instrument lights, since they aren’t. All you have to do is change a bulb, and not turn off the light switch and bump the bulb socket against the metal dash opening and fzzzzzzzzzz. Ask me how I know. This was on a 73, but even through 89 are not fused.
Glad you are handy and now you’ll get intimate with wiring.
Old 03-12-2020, 07:25 PM
Jameel's Avatar
We need a good tutorial thread on exactly what and where to add fuses that Porsche evidently forgot about.
3.0 rebuilt by me
Old 03-12-2020, 07:42 PM
RSBob's Avatar
Here’s the thread on dash light fusing. Dash lighting fuse installation
Old 03-12-2020, 07:51 PM
