-   -   Unfused circuits (http://forums.pelicanparts.com/porsche-911-technical-forum/1054943-unfused-circuits.html)
Quickstep192 03-14-2020 03:58 AM
Unfused circuits
After reading a few posts about smoke and molten wires, I think I’m going to undertake a project to add fuses to the unfused circuits in my ‘73.
Is there a comprehensive list of all the stuff that’s unfused?
gamin 03-14-2020 06:00 AM
Great question. I would like to know also.
tirwin 03-14-2020 06:10 AM
The instrument light cluster is one. There is an old thread here that is a great write-up. Super easy. You just install an inline fuse off the ignition switch with a 1 or 2A fuse. I’ll look for it and post in a few minutes.
Another one is the front A/C condenser fan. It’s on a fused circuit but it can still start a fire (right by the gas tank) if the motor seizes. Several people have lost their cars this way. Porsche added an inline fuse sometime in the late 80s after they realized this error. Another easy fix and Pelican also sells a plug and play kit if you don’t want to DIY.
tirwin 03-14-2020 06:13 AM
Gauge light fuse fix:
http://forums.pelicanparts.com/porsche-911-technical-forum/105819-dash-lighting-fuse-installation.html
tirwin 03-14-2020 06:15 AM
Pelican A/C condenser fan kit:
https://www.pelicanparts.com/More_Info/PEL61207700.htm?pn=PEL-612-077-00&bt=Y&fs=0&SVSVSI=801
shadowjack1 03-14-2020 06:18 AM
Not a fuse thing but I like the ceramic plugs in the head light as a good upgrade. As is the headlight relay.
Pedro '84 Coupe 03-14-2020 06:40 AM
Post #6 here is a good one too
http://forums.pelicanparts.com/porsche-911-technical-forum/671858-smoke-under-dash.html
porsche930dude 03-14-2020 06:45 AM
I couldnt find the thread where almost all the wires were melted behind the gauges that was scary! I seem to recall the cig lighter and glove compartment light are unfused aswell but they might be on the dash light circuit?
911pcars 03-14-2020 03:33 PM
It's better practice, if possible, to locate fuses in a central or obvious location so it can be easily inspected should there be a malfunction years after your memory fades.
For example, the main fuse box.
Sherwood
Peter M 03-14-2020 03:48 PM
Unfortunately the fuse Porsche added is too highly rated to blow before the AC blower wire melts. Hence the need to still add a lower rated fuse in this particular circuit.
RWebb 03-14-2020 03:53 PM
be sure to check the wiring diagram for 1973 or 1973.5 whichever you have
most of the posts above relate to later cars
yours has all those unfused issues but maybe more
I'll be interested to see if there are others since I have a 1973.5
Quicksilver 03-14-2020 07:55 PM
The basic issue is Porsche took the power from the battery, bypassed the fuseblock that is right next to it, and ran it into the dash to all the various controls, then they ran the wires back to the fuseblock, and then finally they ran them to the various loads.
It makes no sense. The fusible protection should be as close to the power source as possible.
It is the one part of the car that just drives me nuts.
Peter M 03-14-2020 10:58 PM
Close! Actually the ash tray and the ventilation control panel lights are unfused. The lamp holder for the ash tray light doesn't take much "bumping" like when installing a new stereo unit for it to short.
The easy way is to add inline fuses from where they powered from the back of the light switch.
Quickstep192 03-15-2020 08:53 AM
A follow up question...
Does anyone know what values the fuse should be for each of these circuits?
Hotshot 03-15-2020 09:57 PM
I’ve read 3A on the triple BK/BL dimmer lights. FWIW, I used the 2.5A inline fuse from the orig radio wiring for my ashtray light.
Travis Neff 03-16-2020 10:05 AM
Heater lever is not fused and ignition hot lead
Quickstep192 03-16-2020 10:18 AM
Is that on a different circuit than the dash lights?
Travis Neff 03-16-2020 10:23 AM
yes different separate circuit. They are unfused on constantly hot (not switched).
Quickstep192 03-16-2020 11:05 AM
Crimeny! What were these guys thinking?!?
Quickstep192 03-16-2020 11:06 AM
Any idea where the “other end” of that connection terminates ?
