'73 911 T Targa
Unfused circuits
After reading a few posts about smoke and molten wires, I think I’m going to undertake a project to add fuses to the unfused circuits in my ‘73.
Is there a comprehensive list of all the stuff that’s unfused?
Old 03-14-2020, 03:58 AM
Great question. I would like to know also.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 03-14-2020, 06:00 AM
El Duderino
tirwin's Avatar
The instrument light cluster is one. There is an old thread here that is a great write-up. Super easy. You just install an inline fuse off the ignition switch with a 1 or 2A fuse. I’ll look for it and post in a few minutes.
Another one is the front A/C condenser fan. It’s on a fused circuit but it can still start a fire (right by the gas tank) if the motor seizes. Several people have lost their cars this way. Porsche added an inline fuse sometime in the late 80s after they realized this error. Another easy fix and Pelican also sells a plug and play kit if you don’t want to DIY.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 03-14-2020, 06:10 AM
El Duderino
tirwin's Avatar
Gauge light fuse fix:
Dash lighting fuse installation
Old 03-14-2020, 06:13 AM
El Duderino
tirwin's Avatar
Pelican A/C condenser fan kit:
https://www.pelicanparts.com/More_Info/PEL61207700.htm?pn=PEL-612-077-00&bt=Y&fs=0&SVSVSI=801
Old 03-14-2020, 06:15 AM
1988 Carrera
shadowjack1's Avatar
Not a fuse thing but I like the ceramic plugs in the head light as a good upgrade. As is the headlight relay.
88' Carrera
79' SC gone (lost to Katrina)
75' Targa gone
72'914 gone
72' 914 gone too
Old 03-14-2020, 06:18 AM
Pedro '84 Coupe's Avatar
Post #6 here is a good one too
Smoke from under dash
2000 Boxster S and 2016 Audi A6
Old 03-14-2020, 06:40 AM
I couldnt find the thread where almost all the wires were melted behind the gauges that was scary! I seem to recall the cig lighter and glove compartment light are unfused aswell but they might be on the dash light circuit?
Old 03-14-2020, 06:45 AM
It's better practice, if possible, to locate fuses in a central or obvious location so it can be easily inspected should there be a malfunction years after your memory fades.
For example, the main fuse box.
Sherwood
Old 03-14-2020, 03:33 PM
Unfortunately the fuse Porsche added is too highly rated to blow before the AC blower wire melts. Hence the need to still add a lower rated fuse in this particular circuit.
Old 03-14-2020, 03:48 PM
AutoBahned
RWebb's Avatar
be sure to check the wiring diagram for 1973 or 1973.5 whichever you have
most of the posts above relate to later cars
yours has all those unfused issues but maybe more
I'll be interested to see if there are others since I have a 1973.5
Old 03-14-2020, 03:53 PM
Diss Member
Quicksilver's Avatar
The basic issue is Porsche took the power from the battery, bypassed the fuseblock that is right next to it, and ran it into the dash to all the various controls, then they ran the wires back to the fuseblock, and then finally they ran them to the various loads.
It makes no sense. The fusible protection should be as close to the power source as possible.
It is the one part of the car that just drives me nuts.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 03-14-2020, 07:55 PM
Close! Actually the ash tray and the ventilation control panel lights are unfused. The lamp holder for the ash tray light doesn't take much "bumping" like when installing a new stereo unit for it to short.
The easy way is to add inline fuses from where they powered from the back of the light switch.
Old 03-14-2020, 10:58 PM
'73 911 T Targa
A follow up question...
Does anyone know what values the fuse should be for each of these circuits?
Old 03-15-2020, 08:53 AM
Analog Air Cooled
Hotshot's Avatar
I’ve read 3A on the triple BK/BL dimmer lights. FWIW, I used the 2.5A inline fuse from the orig radio wiring for my ashtray light.
86 Targa
91 964
13 6 SPD Cayenne
Old 03-15-2020, 09:57 PM
Travis Neff's Avatar
Heater lever is not fused and ignition hot lead
72 914-6 GT Conversion 2.7
82 911 SC Coupe
78 SC Targa Hotrod
Old 03-16-2020, 10:05 AM
'73 911 T Targa
Is that on a different circuit than the dash lights?
Old 03-16-2020, 10:18 AM
yes different separate circuit. They are unfused on constantly hot (not switched).
82 911 SC Coupe
78 SC Targa Hotrod
Old 03-16-2020, 10:23 AM
'73 911 T Targa
Crimeny! What were these guys thinking?!?
Old 03-16-2020, 11:05 AM
'73 911 T Targa
Any idea where the “other end” of that connection terminates ?
Old 03-16-2020, 11:06 AM
