Rodney Nelson's Avatar
What are differences between '72 T and S Models
Hi Everyone,
I'm restoring at '72 T. I would like to possibly build it to S specs and I want to understand all the differences.
Suspension
Brakes
Instruments
Cooling
Engine
Body
Thanks,
Rodney
Rodney Nelson - '72 911T (Undergoing Full Resto), '82 SC (Grand Prix White) Gone for 20 yrs and now back, '86 951 (Guards Red) Caught Fire, '71 911T (Tangerine) Sold, '72 911E (Grand Prix White) Sold, '86 951 (Black) Sold, '79 SC (Grand Prix White) Sold, '71 911T (Irish Green) Sold
Old 03-21-2020, 04:13 PM
wayner's Avatar
In 72 (at least in Italy) they sold S options for your T.
It was cheaper tax wise to option a T to S spec than order an S.
You could ask who has a T with S options
(I think it was basically everything except the engine)
starting with the appearance options like Fuches wheels etc.
SOLD - 914 wide body hot rod
Old 03-21-2020, 04:16 PM
Bill Verburg's Avatar
Originally Posted by Rodney Nelson View Post
Hi Everyone,
Suspension
Brakes
Instruments
Cooling
Engine
Body
Thanks,
Rodney
Suspension;
Same tbars, T had no base sways but the S 15/15 was an option, shocks are the same both had options of Koni or Bilstein
Brakes;
t used M f/r s had S front and M rear, both have the same rotors and 19mm m/c
Instruments;
t had 4 gauge w/the S 5 gauge option
Cooling;
t no frt oil cooler, S has a front fender radiator cooler
Engine;
here's the big difference,t- 7.5 cr 133 SAE hp@5600, S 8.5 cr 181 SAE hp @6500 t has cast iron cylinder, S has a finned alloy jacket around the cylinders, cams were different t 16 30 42 4, S 38 50 40 20, S has bigger ports 36/35 vs 32/32
Body
S has a bigger gas tank oe and front air dam which were optional on T, s has wider al/rubber trim strips on bumpers and side, interior was nicer on S w/ leather option on t
trans is the same, 6" Fuchs std on S opt on T
Bill Verburg
Old 03-21-2020, 04:34 PM
Originally Posted by Bill Verburg View Post
Suspension;
Brakes;
Instruments;
Cooling;
Engine;
Body
Thanks for the info bill.
Could you please explain the brakes? It looks like my T has M calipers, but then drums in the back?
Did the S have aluminum front S brakes and rears were disk? Right?
Also could you please clarify the gauge part? What is extra on the S?
Thanks,
Rodney
Old 03-21-2020, 04:53 PM
There were differences on the T vs S here in the usa
Not all s came with oil cooler. Then there were some with a loop cooler and others with radiator coolers.
Alloy s calipers and sway bars were optional on the T as well as leather. The gas tanks in usa were the same for all models. Plastic larger tanks for row S and of course the RS
4 speed was standard on the T but most were ordered with 5 speeds
70-71 models had more differences than 72-73 range
DRUM brakes? I think you might be confused with the parking brake. ALL 911 cane with disc brakes
Old 03-21-2020, 05:15 PM
Ha! you are right I was thinking about the parking brake. I remember tearing it apart and being careful about the parking brake! It does have discs in the back.
So, the rear brakes on the S and the T were the same, it is just the fronts had the Aluminum S calipers?
Old 03-21-2020, 05:29 PM
Correct. Rear brake systems were identical. Front struts had 3.5 inch mounting spacing on the S vs 3 inch on the standard T.. So you can't just buy S (or A ) calipers and bolt them on.
Old 03-21-2020, 05:51 PM
Rescuer of old cars
Arne2's Avatar
My '72 T was optioned with the Appearance package, 15" Fuchs and F&R sway bars. Many were optioned like this. With these options, the differences from an S are the front spoiler, more powerful S motor, front brake calipers (and associated strut housing) and oil cooler.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 03-21-2020, 06:31 PM
Thanks,
Rodney
All T came w/ M front calipers and M rear calipers, all 911 have a drum parking brake in back, all 911 thru '83 have the same front rotors and the same rear rotors w/ incorporporated parking brake
S came w/ aluminum S calipers on the same rotors as the T w/ iron M calipers
The extra S gauge is the oil combo gauge w/ oil level and temp, many T's had this as an option, like the 6" Fuchs and front spoiler and trim pieces but it also depended on the importer for a specific market, In the US there was an S Package w/ most of the S pieces except for the engine and sways bars
Bill Verburg
Old 03-21-2020, 07:17 PM
Never seen an S w/o a right front radiator cooler, the loop cooler was introduced for MY'73 and may have been used on a few end of the MY72 cars, Yes, the sways and leather and spoiler and 6" Fuchs w/ 185/70VR15 were all options(5.5" steel w/ 165HR15 was std for T), some dealers may have put S calipers on but I've never seen an option code for that, even the S had a standard 4 speed w/ 5 speed option and lsd was another option
T had a std 16.4gal gas tank S 29 gallons which was optional on T
I've still got all the original literature from my first 911 which was a '72
Bill Verburg
Old 03-21-2020, 07:37 PM
Brakes and oil cooler were not part of the appearance group for US cars
Bill Verburg
Old 03-21-2020, 07:38 PM
am i reading this right, S held almost 30 gallons?!...
1971 914-6 GT 3.6
1974 911
1976 911S leaf green backdate 3.2
Old 03-21-2020, 08:17 PM
yes, 85liters for E, S & RS, base T was 63liters
Bill Verburg
Old 03-22-2020, 09:50 AM
cycling has-been
bkreigsr's Avatar
...here's the big difference,T 7.5 cr 133 SAE hp@5600, S 8.5 cr 181 SAE hp @6500
BINGO - plus 48 HP in a 2,300 pound car.
Bill K
Old 03-22-2020, 12:09 PM
