3.2 ICV connection test
I suspect something is wrong with ICV. I tested the actual part and it’s functional. How can troubleshoot the electrical connection?
Old 03-27-2020, 06:05 PM
nb6179505's Avatar
I ordered a new Bosch plug with new contacts and mine works better than ever
84 carrera
Sent from my Pixel 3a using Tapatalk
Old 03-27-2020, 06:18 PM
If you do not have a scope, the best way would be to check for consistent continuity between the ECU connector pins that control the ICV and the pins on the connector shown ?
If you have a scope, look at the signal the ecu puts out to the icv ( with the icv plugged in ) by backprobing. It should look like block waves.
In any case clean the contacts of the connector and icv wth some alcohol.
Old 03-28-2020, 12:10 AM
