help ID unique carb stacks
ID 47mm no taper. overall length 90mm top to bottom. not sure what the second flange is for.
what effect would the extra length have ? (55mm stack for comparison) TIA ![]() ![]()
Unclear on the concept ? Let's see if I can help. 1) You are NOT in the "fast lane" and... 2) You are NOT going "fast enough". **News Flash** You're in the Passing Lane. Any questions ? |
It's a 914 ...
Sometimes people will vary stack length to optimize engine tuning. I don't recognize these, but maybe someone wanted custom length stacks for a 911.
stack
I have seen this before.A standard stack cut and another slipped over to make it taller for mid range torque change.
disband
seems to me you'd have a hard time getting those to tuck into a K&N type rainhat filter assembly. would the Porsche OE air filter assembly take that height? im not aware??
the second flange is for trimming them down to a manageable height?
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
I would think that the 2nd flange is the mounting surface for a filter base-plate.
Wasn't there some high filter assemblies available?
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
