Weber 40IDA - Where to buy parts? Leaky accelerator pump cover
Before I contact different vendors and manufacturers, I wanted to ask here:
My 1979 911 SC has Weber 40IDA 3C carbs. The driver's side carb is leaking slightly from the accelerator pump area. I haven't pulled anything apart because I don't have any spares on hand and the car runs well.
My understanding regarding the accelerator pump leaks is that the cover warps. Flattening the cover may be sufficient in addressing the problem.
Where can I buy replacements parts and rebuild kits?
Old 03-31-2020, 11:22 AM
I have the same carbs and ordered parts from these guys last September:
Rocky Srl
Via Canalazzi 75
Corlo,Ferrara 44123
Tel: +39 3403586934
Web site: Carburatori Italia - WEBER - DELL’ORTO - SOLEX - Rivendita e riparazione carburatori Weber, Dell'orto, Solex e ricambistica
p-iva:IT01571080389
Included in the parts I ordered was the accelerator pump diaphragms. I was happy with the parts.
Lou
Old 03-31-2020, 11:45 AM
Thank you Lou. Not the ideal time to order parts from our friends in Italy, but I'd be happy to give them the business, that's for sure.
Old 03-31-2020, 11:48 AM
I have the original weber manual. I can probably scan it tonight if you think it would be helpful.
1982 911 Targa, 3.0L ROW with Webers
Old 03-31-2020, 12:02 PM
'73 911 T Targa
I was able to flatten mine by sliding it back and forth on sandpaper over a very flat surface. I think I used 1,000 wet or dry and a piece of marble (it was a while ago)
Old 03-31-2020, 12:25 PM
Those covers just need to be resurfaced on some 80 grit and something flat. They get warped from the corner screw tension. Easy job.
206 637 4071
Old 03-31-2020, 12:27 PM
Thanks all. I suppose I can pull the cover and check the diaphragms. I don't want to open a can of worms and not be able to get replacement parts.
Going out for a drive in today's current situation is not to be taken for granted.
Though I do wonder how much of a leak is too much of a leak when it comes to gas.
Old 03-31-2020, 12:39 PM
1QuickS's Avatar
Remove the four 7mm hex nuts securing the top cover of the accelerator pump, leave existing gasket in place and flatten per John Walker's suggestion. I use 220 grit paper. Do not over-tighten the 7mm hex nuts!
You can buy accelerator pump gaskets that PMO makes for their carbs which uses the same pump design as Weber: Accel Pump Diaphragm
The Italian source is found on eBay with the seller name of Alfa1750 so you can order easily that way.
Paul Abbott
Weber service specialist
www.PerformanceOriented.com
Old 03-31-2020, 01:13 PM
Thanks Paul. I've been reading the articles on your website quite a bit lately. Thank you for compiling that information. It is exceptionally valuable.
Between you and John Walker - should I refrain from driving the car with a leaky accel pump cover?
Would you recommend purchasing from youroil.net? I have not heard of that site before.
Thank you!
Old 03-31-2020, 01:32 PM
Sure, if you like fire. Some of them squirt real good.
206 637 4071
Old 03-31-2020, 03:08 PM
I don't.
Driving the car has been a nice distraction from everything going on. Sometimes I ask questions, but I already know the answer.
Old 03-31-2020, 03:21 PM
1QuickS's Avatar
Larry Turner of Weber Carb Parts, PMO Carburetors and Parts, Porsche Posters, engine oil testing is a supplier of PMO and Weber parts, a great guy and good quality parts! I refer most of those inquiring about parts to contact him.
Paul Abbott
Old 03-31-2020, 07:12 PM
I live in the bay area, I buy from Pierce Manifolds in Gilroy.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 04-01-2020, 03:30 AM
l_turn9's Avatar
Thanks for suggesting they contact me, Paul.
Locker537 - I can provide any IDA parts you might need, from diaphragms to complete pumps as well as rebuild kits, jets, venturi's, etc. If the cover is only warped a small amount, using a mirror or small sheet of glass, so you will know you are working on a flat surface, then do as another Pelican suggested and work with 1000# (some people like different grits) sandpaper to flatten the cover. Work slowly, checking your progress every few minutes.
All of the parts you might need, if any are damaged, are readily available. Unless you have a unusual situation, the pumps usually come apart pretty easily, but we never know what people might run into.
re the danger of driving with leaking pumps - fire is possible - which would change a small inconvenience into a major repair job.
LarryT
Youroil.net
Old 04-01-2020, 04:06 AM
Thank you Paul and Larry!
Larry, I will be in touch!
Old 04-01-2020, 06:52 AM
l_turn9's Avatar
Thanks Locker! I'll look forward to it. If possible please use email - it's the easiest way to reach me - info@youroil.net
Old 04-01-2020, 06:59 AM
I carefully cleaned the area with brake cleaner today. I then ran the fuel pump and worked the throttle. I did not start the engine as I did not have time.
I can hear the accelerator pump squirting. The driver side is louder than the passenger side. However, I don't see or feel any leaking fresh gas. I took a couple pictures as well in case anything stands out to others.
Most of the moisture I noticed is on the components designated by the red circle. Any thoughts? For context, I did not start the car for approximately 4 months over the winter.
EDIT: Images fixed...but huge!
Old 04-01-2020, 04:19 PM
clarkd's Avatar
Weber 40 weeping fuel at accel pump cover
My covers were warped. I took the sand paper flat surface route and all was good.
Old 04-01-2020, 04:43 PM
Agree Larry at youroil.net is the go to guy. Helped me with my PMO / Weber issues.
Old 04-01-2020, 06:01 PM
The great guru of Webers, without a doubt, as mentioned, is Mike Pierce of Pierce Manifolds, Guilroy, California. Has done all of the Webers on my old V12 Ferraris and has the machine to straighten out the warped bodies, and correctly flow test the carb. I also tried gently sanding the bottoms of the carbs on a piece of glass, but he gets it right without damaging these rare and expensive units. Has a gazillion Weber parts and is a real car guy. Tell him Steve Meltzer passed along his name. (He was recently named one of the top restorers in the country by Sports Car Magazine. (about a year ago). steve
Fair warned: quality work ain't cheap. s
Steve Meltzer
'69 911E/bastard
Old 04-01-2020, 06:45 PM
