-   -   75S engine rebuild (http://forums.pelicanparts.com/porsche-911-technical-forum/1056860-75s-engine-rebuild.html)
al lkosmal 04-03-2020 01:28 PM
75S engine rebuild
I'm rebuilding a 75S, 2.7 engine.........This is a stock rebuild (it happens). This will be the full meal deal......Thursdays progress......
http://forums.pelicanparts.com/uploa...1585945625.JPG
http://forums.pelicanparts.com/uploa...1585945625.jpg
regards,
al
al lkosmal 04-06-2020 05:11 PM
the seamy underbelly
wow...this one is a mess.....lots of leaks with JB weld used as a seam sealer.....original smog pump manifold and injectors.....this should be a total beeyatch to get apart...however, due to the oil, the exhaust came off without a struggle....this one is definitely due for a rebuild.....behold
http://forums.pelicanparts.com/uploa...1586218101.JPG
regards,
al
fanaudical 04-06-2020 05:56 PM
Is this one staying CIS? Or are you working some induction magic on this one too? :)
al lkosmal 04-06-2020 06:01 PM
No, unfortunately no EFI magic on this one....a stock rebuild....and it needs it.......but I have two other engines underway....a 2.7RS-ish and a 3.2....those two will have to satisfy my EFI obsession.....
al lkosmal 04-10-2020 06:52 PM
messy
Wow....this is a messy one.....however, the oil inside the engine is very clean.....I think that this one leaked so much, it got a constant supply of fresh oil...rockers and cams look great. One head nut was off and the rest of them were so loose, I could just about loosen them with my finger tips....I thought that maybe it was the result of the head-studs pulling a bit.... and it might be....but all cam housing and the case perimeter nuts were also very loose....in fact....almost every fastener, with the exception of the cam nuts and rocker nuts...were not tightened near to spec........it has made taken this one apart pretty easy, to date...although there is one nut, covered with JB weld that might be on pretty tight...... behold the filthy beast....
http://forums.pelicanparts.com/uploa...1586569768.JPG
gomezoneill 04-11-2020 07:00 AM
I like the orange silicone on the intakes.
al lkosmal 04-11-2020 09:44 AM
oh yes....lots of nice sealing attempts on this one....silicone, JB Weld,, copper sealant spray......all the good stuff.
mikedsilva 04-11-2020 02:02 PM
Al, do you do your own machine work? Will you be installing case savers etc, yourself?
Hoping you document what work is carried out on the case.
al lkosmal 04-11-2020 02:16 PM
Nope...heads out to Craig Garrett, case out to Ollie's
al lkosmal 04-11-2020 05:56 PM
innie
Crank looks good.....main bearings are slightly worn....overall, internals are not too shabby.....
http://forums.pelicanparts.com/uploa...1586652841.JPG
al lkosmal 04-17-2020 09:12 AM
head studs
As I was disassembling the engine, the head stud nuts were so loose, I could almost turn them by hand. It took almost no force at all to remove them.......and here is why.
http://forums.pelicanparts.com/uploa...1587139790.JPG
regards,
al
gomezoneill 04-17-2020 09:55 AM
Been working on these cars since 1971. The beauty of those internals still amazes me.
al lkosmal 05-14-2020 11:55 AM
tasty
Even the stock 2.7 CIS pistons and cylinders look tasty, right out of the box......
http://forums.pelicanparts.com/uploa...1589482355.JPG
regards,
al
gomezoneill 05-14-2020 01:33 PM
Is that a 5 cylinder engine?
brp914 05-14-2020 01:51 PM
regards,
al
Well, after 45 yrs, was the heli-coil/threaded insert/case saver/time cert head stud fix debate settled? Or is that like the dreaded dilivar / Supertec debate?
al lkosmal 05-14-2020 03:22 PM
Yes, we're doing everything we can to reduce weight.........
al lkosmal 05-14-2020 03:26 PM
No, the debates continue...we'll need another 30-40 insert threads (no pun intended) to ensure that we gather every opinion out there. It would be interesting to hear what type of oil everyone recommends though...............
regards,
al
al lkosmal 05-14-2020 04:29 PM
shiny heads
The heads for the 75S are looking a lot better now that Craig Garrett (CGarr) has worked them over...........
if you need your heads rebuilt...he is the man.
http://forums.pelicanparts.com/uploa...1589498885.JPG
jimtweet 05-14-2020 05:05 PM
something to be said about stock Al, im in the process of a one off resto now on a rare 911, and really digging the whole restoration thing. Our of my norm, hot rodding, but its fun
Cornerlot 05-14-2020 06:49 PM
Took my heads out to Craig Garrett last week, he's conveniently 1-1/2 hours away so I took the drive in person. He said about 2 weeks...
