Oil Change with front oil cooler
So, finally finished installing the front fender cooler last year. Did my first oil change here last a couple of weeks ago with a front oil cooler. I just did the normal thing, emptying the tank and then engine. It got me thinking how necessary it is to drain the oil that is in the front cooler and in the lines to the front cooler? I figure that the dilution factor of the old oil in the lines/front cooler degrading the new oil would at best be minimal and not all that important. My question is how would you drain the cooler and oil lines if you don' t have the fitting to blow it out and secondly does a lot of ppl here drain it when they do an oil change if you don't have the fitting to blow back the oil to the tank?
Just curious and I did do a search here and read about 6 pages but didn't find any info. Thanks.
Lost 2.7l engine #6141641, drop me a line if you find it.
Old 04-07-2020, 10:45 AM
Reiver
Reiver's Avatar
I don't worry about that as I change oil every 3k...I just change it when as hot as I can get the oil.
At 3k the oil is hardly 'used up' additive wise and with the new 10.5 quarts or so hardly anything to lose sleep over.
De Oppresso Liber
Strength and Honor 5th Legion
Old 04-07-2020, 10:49 AM
John W
You’re correct the new oil gets diluted. A rough guess would be after an oil change you’re already 10% ready for the next one. No worries.
Old 04-07-2020, 11:29 AM
Administrator
Jack Olsen's Avatar
You can add an air fitting and blow it out. But that's crazy.
For 20 years, I've just drained the tank and the case.
Old 04-07-2020, 12:29 PM
Bill Douglas's Avatar
I don't even bother with the case. Almost nothing comes out.
I do an oil change on ALL the vehicles every six months so it doesn't get the chance to go bad.
Old 04-07-2020, 05:33 PM
donbecker1234's Avatar
I just bought a suction puller and evac’d both lines and the front cooler. It was maybe a little over 1 liter total
Old 04-07-2020, 06:45 PM
I think that means there are still about two liters lurking in there somewhere,
Old 04-07-2020, 08:00 PM
I'm open to me having missed some, however I suctioned around 9 out of the tank, and it looked like the remaining that drained from the engine sump put me around 11 or 12.
When I suctioned the front cooler lines, I ran the tube far into the lines (towards the cooler) on both lines.
Old 04-08-2020, 07:41 AM
How is this done? Do you disconnect lines?
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 04-08-2020, 07:52 AM
Thanks for the info fellas... kiinda what I thought on dilution and seriously didn't think making a 15 minute job into hours just to get a a couple quarts of oil... shoot it leaks that much! Be safe and practice social distancing....
Old 04-08-2020, 01:52 PM
I disconnected the lines at the external thermostat in front of the pass rear tire.
Ironically those are usually hard/impossible to remove, but I had leaks there and mine were fairly loose.
I used one of these to suck the oil out:
https://www.harborfreight.com/Deluxe-Manual-Fluid-Extractor-and-Dispenser-56384.html
Works really well.
Old 04-08-2020, 05:17 PM
Like Jack said, just ignore it. After 25 years and over 100,000 miles, I just drain the tank and the engine on my 3.2. About 1 quart or so come out of the engine. I like to see and clean the magnet in the engine case.
The oil in the lines and the cooler are not worth the extra effort.
Old 04-09-2020, 07:37 AM
Just drill a hole in the bottom of the front cooler then install a sheet metal screw with some dum dum on it.
Old 04-09-2020, 09:20 AM
