1984 911 3.4 sleeper hotrod - The end?
You know you have done well when the feedback on your engine is "you may want to look into dialing back the throttle response. It produces too much power too quickly, which makes it more challenging to manage on track."
That was feedback from our chief instructor at a local hpde a month or so ago. The car is a beast, right from the getgo. It really puts hair on your chest. To overuse a cliche, it pulls like a fraight train from any rpm. On the street, you need to be mindful, and you can be "stunting" within a breath or two. On the track it is a monster. 2400lbs wet can do that. If you know my past two build threads on the car (now useless due to the new photobucket "ransom"), you will know a lot of love, effort and thought went into this car. It became my dream car. Enough talk... here is the dyno: (numbers all at the wheels) That works out to 290hp at the crank. On 91 octane. Single plug. 92ft above seal level, 23oC. Please feel free to compare the numbers i get at various rpm's to similar builds. Long story short, vs big cammed, big exhaust 3.4l builds, i match the top end, and beat them in the low end. So what was the formula for my 3.2l? From intake to exhaust... here it is (sort of): - MAF/injectors/dme/chip with cone intake from Sal Carceller. - 91 octane fuel - single plug - 66mm enlarged throttle body (stock 63mm) - no extrude hone for intake runners - 964 cams - max moritz 3.4l pistons with 9.8:1 compression ratio - custom 1.5 inch internal diameter headers (i had them built to my spec... with heat) - custom muffler (designed to my spec) You will note that everything is quite balanced. No huge cams, no huge exhaust. Just well matched/designed components that are #balanced#. The theory is that the intake plenums are tuned for an optimal peak torque and rpm, so rather than fight it, and try to change that, I worked with it, and worked to optimize it further. My goal was to keep the stock peak torque, and near stock redline. In the end, many small changes became synergistic. Sal did the tuning on a mustang and i want to thank him very much. Great guy, and huge support. He hooked me up with a very drivable car, and a great system. The car runs like a top. Also thanks to Larry (you know who you are) on the mechanical side.
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS Last edited by gliding_serpent; 07-13-2017 at 09:54 AM.. |
Under the radar
246 HP and a flat torque curve. NICE.
Thanks for the follow up post. Glad to hear that everything turned out great.
Open Highway Productions
Wow. 8 pounds per hp is huge. Wish they all were like this.
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
those are some amazing numbers out of a single plug- im actually quite surprised- I will have to dyno my mild v-ram 3.6, those are the kinds of numbers I was expecting out of the newer engines.
ps- its never enough power!!!!
81 SC 3.8 Conversion 2017 Macan S INSTAGRAM @tail_spinz |
Congratulations on your project. Your build is very similar to mine, except I used SSI's with Dansk sport muffler w/ single out, and your dyno results are nearly identical to mine. Enjoy it, I believe this is as good as it gets.
My '87 3.4 with MAF project Peter
Peter 1987 Carrera Coupe 3.4 2003 Boxster S (SOLD) 1986 Carrera Coupe - (SOLD) 1984 944 - (SOLD) |
That Guy
I have a similar build that resulted in 252whp/230ft-lbs. Mind you, based on the results of other cars on this dyno i think it is optimistic by about 10-15%. Personally i think i am in the 225whp range.
Mahle 3.4L p&c's Compression 9.65:1 Single plug 91oct 964 cams Still running stock motronic, dyno tuned on the conservative side for reliability. Stock headers, this was with an M&K Euro pre-muffler and no primary muffler. We saw ~10hp drop with a M&K single in/out muffler added. In this chart, the blue curve is with just the pre-muffler. Red is with the full exhaust.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 Last edited by Techno Duck; 07-12-2017 at 04:28 PM.. |
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS Last edited by gliding_serpent; 07-12-2017 at 04:45 PM.. |
Very interesting. 10% correction on your top numbers (without the muffler) is 267hp at the crank. Drop the cat, Pop on another muffler like a dansk sport and you should drop only 3 or so hp from those max numbers. I know my headers and muffler are worth a lot also, as i designed them to optimize my setup.
Like you, i had had sal tune for a more Conservative afr as i track my car, and favored reliability over a dyno princess. My belief is that dynojets are generous for our cars, but at least they are about as standardized as they can get. Quote:
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS Last edited by gliding_serpent; 07-12-2017 at 04:47 PM.. |
I can't be the only one that would love to see some in car action footage!
I will get some gopro video monday/tuesday at the track
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS |
Now you've done it!
Your engine numbers are going to make me put my car on a dyno! About 4 years ago, I built a 3.3SS engine for my SC using 100mm Mahle 10.8:1 pistons, 964 cams, Carrera race prepped heads, early large port CIS airbox, crankfire Electromotive XDi twin plug ignition and SSI exhausts. Starts and runs well and, like you said, "pulls like a freight train up to redline (7500 rpm)! Now I just got to know what the real hp numbers are!
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
What interested me was that i expected to see a beefier bottom end with the ssi's. What I found was that the proper sized headers improved my entire power band. Everything shifted up. I have seen some 3.4l dynojet nombers with big cams and exhaust, that lost on the bottom end, and did no better than the top end on my build. I am not saying i have the one engine to rule them all, but maybe moderation and good intake/exhaust design is key to make the most of a series of small changes.
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS Last edited by gliding_serpent; 07-13-2017 at 09:53 AM.. |
Counterclockwise?
Did you dyno the car before the build to get a baseline?
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
Yes. Depending on what you believe, it was about 260hp at the crank with ssi's and a dansk sport. The remainder was the same for the engine.
No baseline on the engine when it was a stock 3.2, but it had way less low end and mid range grunt (it also came with near no muffler and a chip).
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS Last edited by gliding_serpent; 07-13-2017 at 10:15 AM.. |
gearhead
Well done, John.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Thanks, the gearset you helped me put together for our local track is perfect (I run a ~8% shorter ratio) and the LSD has been a great addition. The car puts the power down like a champ, and is very stable under braking. The wevo short shift is also brilliant.
We did a tranny oil (swepco) change this spring and my builder was amazed at how little metal was in the box. Barely anything. He never saw such clean oil in a 915... and my car is frequently tracked too!
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS Last edited by gliding_serpent; 07-13-2017 at 10:51 AM.. |
A few more photos
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS Last edited by gliding_serpent; 07-13-2017 at 04:08 PM.. |
