which one do yall recommend?
https://www.kroonwireharnesses.com/inline-fuse-for-dashboard-illumination-lights-1965-1989
http://carmagic.us/fuse.html
1987 Porsche Carrera Coupe
Old 02-04-2024, 05:31 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #121 (permalink)
When I started this thread (21 years ago!), I used one like the carmagic. Smaller, lighter.
Old 02-05-2024, 01:19 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #122 (permalink)
I used a mini fuse from the FLAPS. Nothing fancy. That being said, I’ve been very satisfied with Kroon products.
Old 02-05-2024, 08:57 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #123 (permalink)
5 bucks. ordered!
thanks!
Old 02-05-2024, 09:46 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #124 (permalink)
Dash lighting fuse installation
I have a 1984 911 Euro targa and I'm trying to add the inline fuses recommended on the forum. On my car, circuit 58a on the light switch has 3 black and blue wires coming off of it. One of these wires is about 3 or 4 inches long and has a white plug connector at its end. On my car this connector is not attached to anything and I cannot find the opposite connector or a loose wire of any kind to attach it to. Before I put everything back together I thought I would ask if anyone here knows where that wire is supposed to go. My car has a metal brace under the light switch so getting that switch in and out is a fight. I'd like to get it right the first time.
Also, the two bulbs that light up the ventilation control box have come out of their sockets and I am having a heck of a time trying to get them back in. There is just not enough room for my hands. Any advice there would also be appreciated.
Thanks.
Old 02-14-2024, 08:53 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #125 (permalink)
GeorgeK: Thanks for the Dash Light Fuse tutorial. My 77 911 switch was not accessible as you described, so I removed the switch and installed the fuse as you described. Good video shows how to remove the switch. https://www.youtube.com/watch?v=MRnE4JYk7Kg
Old 09-25-2024, 07:44 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #126 (permalink)
Addendum: I caught some static electricity while I was wearing a wool sweater and stepping out of the car, touched the light switch to turn it on, and blew the bulb powered by a green/white wire that indicates the lights are on. Also burned up the brown ground wires between the speedo, the tach, and the pressure/temp gauge.
So, I have added fuses both for that green/white wire and the black/blue wire. And replaced my once crispy wires. And resolved to replace my metal Rennline light switch with the old rubber kind. And maybe I won't wear wool for a little while.
Old 01-09-2025, 06:32 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #127 (permalink)
PCA Member since 1988
Static electricity doesn't burn wires. It's high voltage, but very low amperage. Something else cause those wires to burn.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 01-09-2025, 11:21 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #128 (permalink)
Am I correct in thinking that if you have relays fitted in the headlamp circuit then this negates the need for the fuse? I’m not too clever with electrics, hence the question. Thank you
Old 01-09-2025, 11:34 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #129 (permalink)
Ian, no.
2 different circuits.
Old 01-10-2025, 04:04 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #130 (permalink)
I got a pretty good jolt, but I agree, it appears to have been a confluence of things. The wiring was already seeing a lot of heat that day, I imagine; I was turning the car on and off a lot because I was running a lot of errands and waiting in line at the emissions testing center (twice!).
The main issue, which I found after I posted, was that the LED bulb in the speedometer on the green and white wire circuit had not been installed perfectly. The bulb's connecting end was sitting on the connector at a weird angle; somehow, the socket had come out of its little hole. Top tip for replacing those little bulbs: be sure to give the wire to the bulb a little "tug" to make sure the bulb socket doesn't come out of the hole. I think my bulb shorted and routed currency to the body of the gauge and the ground wires, which is why they burned.
Old 01-10-2025, 10:46 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #131 (permalink)
That makes more sense.
Old 01-11-2025, 12:23 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #132 (permalink)
If anyone needs, I can make a few more of these as I ordered all the bits in bulk and have at least enough connectors to make 5 more. Just cover the cost of parts and shipping.
Old 01-21-2025, 04:22 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #133 (permalink)
Perfect job, looks like mine so many years ago.
Old 01-22-2025, 08:43 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #134 (permalink)
A separate inline fuse is a good solution. Being frugal and expedient, I would attach the instrument panel wire to the protected side of an existing fuse in the box. Say, the signals or headlights.
Old 01-22-2025, 02:58 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #135 (permalink)
